Author Topic: Versions of Omega with Cruise as standard ?  (Read 6344 times)
Bo Bo
  • Coventry
Re: Versions of Omega with Cruise as standard ?
« Reply #15 on: 04 November 2006, 21:53:24 »
I learned not to be very impressed with my local Vauxhall dealers.
Can anyone recommend any good ones up North ?
Or anywhere for that matter?
« Reply #16 on: 05 November 2006, 11:49:58 »
To clarify the earlier posts...
Cruise can be retro fitted to any Omega, it makes no difference if facelift or prefacelift.
On 2.2, 2.6, 3.2 petrol models, a 4 wire cruise indicator stalk (Part 9181011 - £32) is required, and possibly clutch switch (£10 ish) if manual (some have them, some don't). The Engine ECU needs to be enabled - some dealers charge standard £45, some want a lot more.  My charge is £35 for members with 50+ post rating here...
On 2.5TD BMW diesel, a 2 wire cruise stalk is required. Job done.
On 2.0, 2.5, 3.0 petrols, an ECU/Actuator, throttle cable, 4 wire cruise stalk (smae part as 2.2,2.6,3.2), a 4 pin brake switch and a clutch switch if manual. No Tech 2 required. Parts should be around £30 - £40 from breaker
tommoynihan
« Reply #17 on: 05 November 2006, 16:27:50 »
Are the two cruise control switches at the end of the indicator stalk labelled 'S' and 'R' ?
Salty
  • Fleetwood
« Reply #18 on: 05 November 2006, 16:32:31 »
The S & R buttons should be on the wiper stalk and are for the MID/TID. The cruise buttons are on the indicator stalk and should be labelled + - and 0 I think they are only two switches the + & - is like a rocker switch and is the top one.
« Last Edit: 05 November 2006, 16:34:23 by salty »
« Reply #19 on: 05 November 2006, 16:59:46 »
Cruise switch consists of 3 buttons on end of indicator stalk, labelled I, R, 0
