Author Topic: screeeeechhhhhhhh!!!!!!  (Read 7688 times)
wheels-inmotion
Re: screeeeechhhhhhhh!!!!!!
« Reply #15 on: 21 August 2006, 19:34:54 »
had the wheels re aligned,everything seems ok now..even said come back in 2 weeks and we will re check it!
wheelsin motion i might make an appointment to come and see you if poss? how m,uch roughly will it cost me for all 4 wheels ???
You have a pm
wheels-inmotion
« Reply #16 on: 31 October 2006, 19:26:44 »
Why do you feel you need it set again, what problems are you having now?
zoltron
  • Blackheath, Rowley Regis
« Reply #17 on: 31 October 2006, 20:38:13 »
I had a terrible screeching from the front wheels and still do slightly, I had my geometry adjusted last thursday at chemix in halesowen. the before measurements were terrifiying.
Left Front                                                Front Right
Camber -1*46'                                        Camber -2*31'
Caster 4*38'                                           Caster 5*05'
Toe -12.6mm                                          Toe -13.0mm
                         Total Toe -25.6mm
                         Steer Ahead 0*01'
Left Rear                                                 Right Rear
Camber -1*43'                                         Camber -1*47'
Toe 0.7mm                                              Toe 0.6mm
                          Total Toe 1.3mm
                         Thrust Angle 0*00'
After Results were much better
Camber -1*48'                                        Camber -1*18'
Toe 1.0mm                                             Toe 1.1mm
                           Total Toe 2.1mm
                          Steer Ahead 0*00'
Camber -1*39'                                         Camber -1*44'
Toe 1.3mm                                              Toe 2.0mm
                          Total Toe 3.3mm
                        Thrust Angle -0*02'
I was told the left caster could not be adjusted and although the value was incorrect it was not worth going to the expense of getting it sorted as it could be down to a machining fault at production. anyone got any feedback on the above values and slight squeeling from the one front tyre. I'm thinking the rubber may just be a little softer on that tyre.
wheels-inmotion
« Reply #18 on: 03 November 2006, 20:58:02 »
They have done a good job, other than the NSF camber is still to deep for my liking... But i am a fussy sod!
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #19 on: 04 November 2006, 07:11:05 »
Zoltron....how much did it cost as I'm not too far from Halesowen.
I like red cars
zoltron
« Reply #20 on: 05 November 2006, 15:46:27 »
It was nearly £62 with the VAT but they did have to do all 4 corners of the car, it drives like a dream now. Steering used to be very heavy, now its very light and it got some getting used to.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #21 on: 05 November 2006, 18:34:42 »
Cheers :y
I like red cars
