Author Topic: Climate ECU  (Read 6426 times)
Climate ECU
« on: 09 October 2006, 21:55:13 »
Does anyone know where the climate control ECU is situated. I think mine is duff :'(
Re: Climate ECU
« Reply #1 on: 09 October 2006, 22:04:57 »
Pre facelift - its the bit you can see, ie the display bit...
Matchless
  • Nottingham
    • A white van
Re: Climate ECU
« Reply #2 on: 09 October 2006, 22:10:44 »
Whats it doing / not doing?
Re: Climate ECU
« Reply #3 on: 09 October 2006, 22:14:22 »
Ive had nothing but trouble with the Climate Control in fact its never worked all I get is cool air. The pipes running through the bulkhead get warm and if I disconnect the yellow plug at the back of the control panel I can get warm air. I tried reseting by holding the Auto and off buttons and you can hear clicking but that hasn't helped. I spoke to the previous owner and he said he shorted the circuit board at the back of the Climate Control changing a bulb so he bought a second hand panel and fitted that but it still didn't work and with winter around the corner I need to get it sorted. I have noticed when I turn the ignition off I get -- in the Climate display any ideas.
Re: Climate ECU
« Reply #4 on: 09 October 2006, 22:15:32 »
saloon and estate run different configs, not sure if that would cause your problem...
Re: Climate ECU
« Reply #5 on: 10 October 2006, 17:24:56 »
Cheers Jaime so you think the previous owner may have replaced the controls with one from an estate?
Taxi_Driver
Re: Climate ECU
« Reply #6 on: 10 October 2006, 19:03:52 »
Im pretty sure -- on the climate display means climate ecu is unhappy about summat....so as its the 2nd climate panel fitted and still doing it....suggests the shorting did other damage to summat else....any chance you can get the codes read??
Ive got a cheapo tech2 and that will read the climate ecu on mine, but dunno about yours sorry
Re: Climate ECU
« Reply #7 on: 10 October 2006, 21:45:24 »
I will see what happens at Santa Pod if Jaime takes his Tech2 :y
Re: Climate ECU
« Reply #8 on: 10 October 2006, 21:46:52 »
is the sampling fan working?
Re: Climate ECU
« Reply #9 on: 10 October 2006, 22:25:54 »
Yep works fine
Re: Climate ECU
« Reply #10 on: 11 October 2006, 11:19:29 »
Bugger...I binned the main circuit board for one only last week.
Re: Climate ECU
« Reply #11 on: 12 October 2006, 11:17:25 »
Ive got one off Ebay so hopefully will have a heater for the weekend :y
The Barge Captain
Re: Climate ECU
« Reply #12 on: 12 October 2006, 23:09:55 »
Just blown mine up changing a bulb as well! (see my thread in general chat "Oops - just blown up my climate control")
Is this a common problem?  Is it something anybody else has seen?
Re: Climate ECU
« Reply #13 on: 12 October 2006, 23:14:13 »
Hi BC mine is the same as yours the previous owner was changing a bulb when it blew so he replaced it with a second hand one but the heater has run cold since then so im hoping that the one I have just bought will solve the problem :y
Re: Climate ECU
« Reply #14 on: 13 October 2006, 17:33:28 »
Well ive changed the circuit board todat and ive now got a working heater :y All ive got to do next is find out why the aircon doesn't work :(
