Author Topic: Alloy wheel stuck!! Help?  (Read 7785 times)
Doughboy
  • Edinburgh
  • ?% Tax on Fuel, Fags and beer(I luv em all) bstds!
« on: 01 November 2006, 14:54:40 »
Any ideas on removing an alloy wheel that appears to be seized on?
All nuts are out but the wheel is giving me problems, an hour spent on it so far. Just want to give them all a good clean :-/
[size=20]I want that one!!![/i][/size]
RossPhim
  • Morayshire, Scotland
  • The blue oval now-a-days!?!
    • 2.2 TDCi TXS
Re: Alloy wheel stuck!! Help?
« Reply #1 on: 01 November 2006, 15:23:34 »
Give it a good kickin ........ honestly.
But be careful you don't damage yourself or more importantly .....the alloy.
theolodian
  • I need a new avatar.
« Reply #2 on: 01 November 2006, 15:34:45 »
Yeah, sit down facing it and alternate kicking each side with your heel.  Be ready to pull your legs out of the way when it goes.  Stop as soon as it shifts at all.  Don't have the car too high, and don't knock it off the jack.  Putting the spare under the front seat (if front wheel) face-down is a decent safety measure.
Doughboy
  • Edinburgh
« Reply #3 on: 01 November 2006, 15:35:46 »
Been kickin the **** out of it for ages, feet are knackered now :( Was tempted to bring out the sledge hammer.
Bit stuffed if I get a flat as I aint got rescue cover. Might go to Kwick Fart and ask them to check my brake pads, give them the headache of getting the bloody thing off ;D
theolodian
« Reply #4 on: 01 November 2006, 15:38:47 »
Sharp hits are the trick, not force.  You could try a large dead-blow hammer.  Whatever you do, it sounds like you need to coat the hub centers when you put them back on.
Doughboy
  • Edinburgh
« Reply #5 on: 01 November 2006, 15:45:56 »
Had to do that on the rear as they were the same, came off after 5 mins of tool abuse though. Just going to wash the rest of the car and have another go at the front wheels tomorrow.
« Reply #6 on: 01 November 2006, 16:00:27 »
I can't guarentee the safety point of this method but it's worked for me. After beating ten colours of the proverbial out of my brother-in-laws wheel to romove it after he ran out of brake pads, I put the wheel back on with the nuts on loose. I then drove the car forward a couple of [size=16]FOOT[/size] and jabbed the brakes on hard. The wheel gave up and released from the hub! :)
« Reply #7 on: 01 November 2006, 16:09:17 »
yours is a fairly new facelift too  :-/
Mine came off really easily when i did mine.... guess its the first time the wheels have been off or the last garage did not do a good job.
As Theo says get a large hammer or mallett, put it on an axel stand to make sure it does't get nocked off the jack. And give it some abuse!!!
Allthough Andy B's way sounds more fun!  ;D
Doughboy
  • Edinburgh
« Reply #8 on: 01 November 2006, 16:39:19 »
will do both tomorrow, Andy B's could be fun(will let you know if I survive ;D).
Can only assume they have been off before as there is sticky pad marks for ballancing.
« Reply #9 on: 01 November 2006, 17:08:11 »
"I put the wheel back on with the nuts on loose"
Doh! I've just read properly what I'd written! Obviously I didn't put the wheel back on cos I couldn't get it off in the first place! I meant that I put the nuts back on but loose.
But I'm sure you all realised what I'd meant to say.  :-[
« Last Edit: 01 November 2006, 17:08:52 by Andy_B »
Salty
  • Fleetwood
« Reply #10 on: 01 November 2006, 17:56:56 »
When I've had this problem I found loosening the nuts on the wheel, and with the car on an axle stand to allow rotation of the a series of blows with a rubber mallet to the back face of the rim of the wheel has done the trick.  Rotate the wheel so you gave hit the rim at various points around its circumference, and give it a good clean before you put it back on.
mijfife
  • Rosyth, Fife. Scotland
  • AAARRRRGGGGGGGGG, IT'S WAS ONLY A GLS!!!!!!!
« Reply #11 on: 01 November 2006, 19:11:36 »
I've tried Andy B's method with good results before, shouldn't need to go more than a few feet in either direction before it loosens enough to come off.
Cheers Jim
The fleet consists of a Singer Chamois Coupe, an Imp based kit car - BS Nymph, and a Kawasaki GPZ 900R (& a Toyota RAV4 LPG for the work horse!)
Gwilym
  • Bridgwater, Somerset, UK
« Reply #12 on: 02 November 2006, 10:38:28 »
You must have your seat up very high to get a spare wheel under it :y
« Last Edit: 02 November 2006, 10:39:47 by Gwilym »
White '00 3.0 MV6 Estate (Ex Met Police Firearms Car)
Rob.
« Reply #13 on: 02 November 2006, 12:09:26 »
I've always found this to be the safest way, if you only have a metal faced hammer as opposed to a dead blow hammer then hold a block of wood on the back side of the wheel first, then belt the S**T out of it keep rotating and it should just pop off  :y
Rob.
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #14 on: 02 November 2006, 18:10:44 »
putting some coppaslip on the hub before refitting the wheel should stop it happening again, it's the corrosion between that and the alloy that makes it stick, the same reason why wheel bolts on alloys jam (abeit being done up too tight with an air gun doesn't help) - coppaslip on the shoulders (not thread) of the bolts before refitting sorts that one too ...
