Author Topic: Washer Bottle - Estate  (Read 2359 times)
SMS01
  • Altrincham
  • Black Omega 3.0 manual estate 'P' reg
« on: 16 November 2006, 14:02:52 »
Has any one had any experience with leaks on these things?
I am getting to the point where I need to do something with my P reg estate. If I fill the bottle up it immediately starts draining, leaking from the front onto the floor. It leaks for so long then stops leaking. Obviously with the impending months, I will need to use it a lot so would like to fill it properly then check levels every week or so.
Are these bottles prone to splitting or are there rubber o rings which dry up (car was stood for approx 12 months before I bought it) or is there anything else with them which can frequently go wrong.
I also take it that it is a bumper off job to get to the bottle. I should mention, has headlight washers so more piping and bigger tank is fitted - have also noticed that the drivers headlight washer often takes a couple of squirts to charge up - suggestive of a leaky pipe?
Any advice from anyone with experience getting these things out or with problems from leaks would be greatly welcome!
Steve
Re: Washer Bottle - Estate
« Reply #1 on: 16 November 2006, 14:30:54 »
Steve
Both pumps (washer and headlight washer) have ribber grommets, so possible pump isn't fully seated.
Split pipework is another possibility.
Marks_DTM_Calib hasn't been near it, has he  ;D
You're gonna have to whip bumper off and investigate further I'm afraid. Bumper comes off in 5 mins if the phillips screws in wheel arches come out easily...
