I've killed it now :(
Started by JamesV6CDX, 17 November 2006, 22:10:32
I agree Jamie
Ive replaced the starter this afternoon, had all the inlet manifold off in the process, and it's now back together.
Heaved a big sigh of relief when it cranked as normal (the old starter STANK of being burned out) = so the electrical issue is fixed :)
However, still won't run. Smells very petrolly though, still "hisses" and won't fire. Again, I may have soaked the plugs, so I'll try a dry/clean set before doing anything too drastic - other than that,
I'm thinking It's either a DIS pack problem - or a fuel delivery problem. Given the smell of fuel in the Engine, I guess there is fuel there though.
I've checked fuse 18, this is fine. I can also hear fuel being pumped to the rail, when I connect the battery.
So, I'm going to A) Try a clean set of plugs now it cranks... B) Get hold of a DIS from the scrappy as soon as I Can and try swapping that out
If anyone else has any further thoughts/ideas on what I can do I would love to hear them, because if the above does not work, I've drawn a blank.....
