Vauxhall dealer Killed my Car!
Started by Rock, 09 November 2006, 19:18:50
Rock
QuoteYou really do not want to know....
Oh go on, i really do.....
[move] Cambelt changed 03/12/06. [/move]
Several thousand for the unit, several hundred for the CANdi, and over a thousand a year for TIS subscription....
Rock
QuoteSeveral thousand for the unit, several hundred for the CANdi, and over a thousand a year for TIS subscription....
:o Wow! Think i'll buy a couple then!  ;)
Taxi_Driver
Quotei read that a tech2 can do a compression test on the cylinders
:o
Now that would be impressive. But I suspect it can't  :-?
Apparantly it can.....ive read up a bit on tech2....to see i can justify buying one  :-/
You can put in a mode where it increases the idle revs (hence why i said in earlier post i should be easy for it to control the idle revs) to about 1000rpm iirc then it shuts offs one injection valve at a time....and revs should drop by 100rpm on each cylinder it does it on, if compression is ok (think this might have been for a v6 tho  :-/ )....i remember from what i read that revs might drop by another 50rpm if cooling fan cuts in......this reading came from a prog that i dont have  ;)
Ah, right, so can't tell you compression, but hints that compression is OK?
If you are thinking of getting one, you need more than Tech2.  To authorise it to do certain stuff, you need a valid subscription to TIS complete with valid Vx registered dongle.  For your Veccy-C, you also will need a CANdi lead...
Well yes...i guess so.....doesnt tell you the compression figures....but assumes if engine revs drops by 100 rpm you should have about right compression on each cylinder......tech2 + other stuff would be nice....but ive got to buy another car....prolly another VeccyC by Jan so this will b4 tech2....tho i will prolly go for eml327 in the meantime  :-/
theolodian
I think that the fully loaded ones are about $6,500 + tax in the states.
[move]Trains may have been invented here, but public transport is a foreign concept![/move]
Had a call from Rock earlier, sounds like good news :)
I'm sure he'll be along shortly to give the full story, but looks like a few things that had to be changed.
Rock
Yep, i haven't picked the car up yet but apparently its now all done and running like a dream again....
Here's what fixed it..
1) Replacement coil packs for banks 1 & 2.
2) Replacement Throttle assembly (including the electric dbw stuff)
3) Replacement Air flow sensor.
Coil packs apparently solved misfiring.
Tech2 was unable to control throttle, and replacing the throttle assembly solved this.
After replacing the throttle it was still not behaving 100% but ALOT better than previously. They changed the air flow sensor on a bit of a guess and it fixed it.
Now all running perfect, and no new fault codes being stored. Not sure why no fault codes were being stored for air flow but am just happy its running again.
Taxi_Driver
theolodian
Good that you solved it!  Always hard when more than one thing is wrong.  Don't worry about MAF codes.  They always die without codes, not just VX either.  Only way to check is to read g/s during a thrash around the block.
Markjay
#99
It seems to me that you have a problem with coil packs for banks 1 & 2, the throttle assembly, and the air flow sensor - I would change all three.
Oh, you've just done that and it all works now? So I was right all along!
;D ;D ;D
Glad it's sorted mate!  :y
Alas, no more Omegas....
Judging by the fact Rock hasn't posted this morning (he was picking up earlier today), I imagine he's out enjoying his Omega :)
EddieX
Glad you got it sorted Rock. Thank god (or whoever you pray to in Omegaland) you didn't take my advice and start thrashing 3 kinds of s**t out of the cats. That WOULD have been an expensive mistake :-[
"Onwards and Downwards"
Rock
Yes i picked the car up yesterday morning and i have been out enjoying it. It feels better than it ever has :)
Thanks to everybody for the advice, general comment, and moral support!  :y
QuoteYes i picked the car up yesterday morning and i have been out enjoying it. It feels better than it ever has :)
Really pleased its all sorted at last :y
Shame about the cost though  :'(
Auto Addict
I like red cars
