Pages: [1] 2 3  All   Go Down
Author Topic: Can anyone shed some light on this weird fault?  (Read 10365 times)
Andiman
  • Burton-on-Trent
« on: 17 November 2006, 09:25:23 »
Hello all,
As promised (in the new members section) I am requesting someone's knowledge and ideas on a problem I have. Please please please someone shed a bit of light on this one?
Ok, have been looking for an Omega for some time now, always been into my Vauxhalls, and found a different one the other day.
It is an N reg (1996) Omega 2.0 Select petrol with LPG conversion on it. No tax, but MOT until July next year. At £400 I snapped it up - totally skinted me, but couldn't afford to turn it down.
Have only driven it once, but that was enough for me. I noticed this problem at the time, but figured that it should be curable. However now I think  need a few clues.
Right, the clutch takes right at the top of the peddle, so thinking either new clutch or cable needs adjusting - will be looking into that later. Not a problem.
No water / mayo in the header tank, on the dipstick, or under the filler cap. All fine there. Header tank holds pressure and car gets warm. Not seen if it overheats at all, but when you first turn the blower on, faint smell of old water.antifreeze blows out of the vents for a couple of seconds or so then it settles down. Odd, but not horrendous.
Enough waffling, down to the problem. The stupid thing hates loathes and detests hills. It loses power - to the point where you have to drop it into first and floor it to get up them. This is only in petrol mode - the gas needs a refill so not had chance to test that yet. Never come across this problem before, so was wondering if it could be the cat? No other ideas.
The engine (which has done 182000 miles) purrs and is so quiet in the cabin. The gearbox is still solid - most cars at that sort of mileage have a gearstick that feels like you are stirring porridge, but this is excellent so no wear as such on the brushes. the gas appears to be ok, but as previously stated, not tested that yet. All electrics are working except the sunroof - but I think it needs reprogramming. Found that bit in the book! Got to program up  a remote keyfob that should arrive today (tenner off ebay!)
So may have a dud, or it may be a good one - hopefully a good one as generally don't have much luck on cars.
If anyone could come up with any ideas, I will be indebted to them.
cheers
Andi  :y
Re: Can anyone shed some light on this weird fault
« Reply #1 on: 17 November 2006, 09:41:16 »
Hello all,
cheers
Andi  :y
Runs fine on the flat then, just hills?
BTW, they keyfob won't work without being programmed to car.  If its the radio type (as opposed to older infra red), this will require a Tech2, and you will also need your immobiliser PIN (which is on your 'carpass')
« Reply #2 on: 17 November 2006, 09:43:36 »
With regarded to the lack of power, I'm thinking along lines of DIS, though I suspect one of the experts will have a better idea.
Whatever, it would be advisable to also clean the breather system on it.
nixoro
  • Hitchin, Herts
« Reply #3 on: 17 November 2006, 10:16:51 »
Ok having read your post as jaime says I would firstly check the breather system and make sure there are no leaks coming from the exhaust.
Just curious but is the engine management light on at any point when the engine is running.
Your lack of power uphill could be caused by the clutch slipping.
Do the revs go up but the speed stay the same or should I say take a while to catch up, what do the brakes feel like, any signs of clutch fluid drop in the brake/clutch filler pot under the bonnet.
Matchless
  • Nottingham
    • A white van
« Reply #4 on: 17 November 2006, 10:28:33 »
Can you confirm the engine management light (EML) behaviour please.
Should come on when ignition turned on then go off as soon as engine started.
(just want to be sure that a previous owner / mechanic hasnt removed the bulb to hide a problem)
Andiman
  • Burton-on-Trent
« Reply #5 on: 17 November 2006, 10:30:58 »
Hi folks,
firstly, many thanks for coming back so quickly.
I have just spoken to the previous owner who has lost the security code/carpass info - so have spoken to Vauxhall and they will furnish me a copy at the extremely generous' (sic) price of 20 quid. Gee, thanks Vauxhall!
Moving on, there appears to be no clutch slip - the engine doesn't race at all. The brakes feel fine and I must admit having only had the car dropped off late last night I haven't had chance to do any more than start it this morning - it started first turn of the key, so quite impressed there.
Oh and the sunroof reprogrammed perfectly - so more good news.
With regards to TheBoy's comment about the keyfob - total agreement with you there, the one I have bought is the type that integrates with a key - and won't play ball at all! Bugger!  >:(
The exhaust does not appear to be leaking - very quiet. No noticable loss of fluid under the car, but will check under the bonnet shortly.
Right, the management light.
This appears to have taken a long and much wanted holiday. No evidence of the bulb lighting up at any time - as I said previously, am very fond of Vauxhalls, so know that it should light on and just before engine start, but it is noticable by its absence. Possible bulb blown - or something more mysterious - ie removed. Hope only bulb blown, need to strip the dashboard out - anyone know how to do that? Done it on a '96 Vectra before, but unsure about this car as am always worried about the airbags.
Will check the breather system - the rocker cover has leaked oil out and this is apparent on the engine and a small amount on the gearbox from this leak. Highly suspicious of blocked air throughway.
Any other ideas?
Cheers
Andi
Bo Bo
  • Coventry
« Reply #6 on: 17 November 2006, 10:35:51 »
There's a "how to" in the maintenance section, click here, only takes a few minutes.
nixoro
  • Hitchin, Herts
« Reply #7 on: 17 November 2006, 10:37:56 »
When you have the engine management light working I would be tempted to try the paperclip test mentioned in the FAQ section
May show some new or old codes affecting the running.
http://www.omegaowners.com/forum/YaBB.pl?num=1152601768
« Last Edit: 17 November 2006, 10:40:31 by nixoro »
Andiman
  • Burton-on-Trent
« Reply #8 on: 17 November 2006, 10:38:47 »
Thanks for that Bo Bo, will go and have a play in a few minutes. Question.... is it best to drop the power to the battery to do this as I know on Vectras the airbag warning light can come on and stay on otherwise.
I am thinking this would be wise to do anyway?
cheers
Andi
nixoro
  • Hitchin, Herts
« Reply #9 on: 17 November 2006, 10:42:37 »
cheers
Andi
I usually do this with the battery disconnected also make sure you have the radio code handy and also you will need to reset the one touch windows and the sunroof.
Make sure the car isn't run at any time with the dash missing as when its all back together the airbag light will show.
HTH
Andiman
  • Burton-on-Trent
« Reply #10 on: 17 November 2006, 10:48:00 »
Nice one guys,
Am now armed with a toolkit and some butter knives - and a missus howling "No, no, it is fine, leave it alone' - she has so much faith in me   :-[
Will be back on here shotly - will swap the bulb out with the dash headlight bulb - don't need that one for the moment. Never got spare bulbs when you need them  :(
Be back shortly.
Cheers
Andi
« Reply #11 on: 17 November 2006, 11:22:17 »
I fear the bulb is missing to hide a fault...  ....there are some scumbags out there  >:(
Andiman
  • Burton-on-Trent
« Reply #12 on: 17 November 2006, 11:42:28 »
I agree!
The bulb was missing - replaced it with the headlight bulb.
Did the test.
Oh fun!
16
135
61
Found 16 - knock sensor signal circuit fault (what the hell is that?) - I know what the knock sensor is, but reading no voltage change  :o
135 - not a clue!
61 - Fuel tank vent valve low voltage - not a clue.
BTW now the computer isn't working! Never had a radio in it when I got it, so computer side doesn't work, but now no date or time!
ARSE!  >:(
Andi
« Reply #13 on: 17 November 2006, 11:47:40 »
Fix knock sensor first - that will really hold it back, the other codes may disappear.
Rare for knock sensor itself to fail, often the cable damaged.
Sorry, not sure where it is on 4 pot engines...
« Reply #14 on: 17 November 2006, 11:49:26 »
Computer will work without radio.  Possibly the movement having dash out has caused the old bulbs in display to blow...
Pages: [1] 2 3  All   Go Up
