Author Topic: Ignition key wont turn  (Read 4897 times)
Peanuts
« on: 23 November 2006, 21:52:25 »
Hi
2.0 ltr GLS pre-facelift. Auto 1998/9
Had starter problem for some time. was going to get the starter motor looked at. BUT now the ignition key wont turn in the barrel.  anyone else had this prob, if so what is the cost of replacement parts, if they can be replaced.  getting realy fed up problem after problem.
Cheers.
Re: Ignition key wont turn
« Reply #1 on: 23 November 2006, 21:55:45 »
I think there was a similar query a few months back, involved taking barrel apart, but care reqd. Hopefully one of the gurus will be along shortly with any help/precautions/solutions...
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #2 on: 23 November 2006, 22:35:13 »
never heard of this before  :-/ presume its linked to your previous problem - just let a starter and ignition go too
Markjay
  • London
« Reply #3 on: 23 November 2006, 23:42:29 »
I would squirt some WD40 into the barrel using the tiny tube that comes with the can and leave it overnight before deciding to take it apart..
Also - don't overlook the obvious - is the steering wheel locked?
Alas, no more Omegas....
kjon51
  • Oldsville - East Sussex
« Reply #4 on: 23 November 2006, 23:48:25 »
And don't overlook the even more obvious - is it the right key? :-/
You never know  :-[
Markie
« Reply #5 on: 23 November 2006, 23:51:35 »
is the key bent - do you have the other to try ?
Boiler Man
  • Sale, Manchester
« Reply #6 on: 24 November 2006, 01:47:01 »
Had this problem before on my 98 GLS, Assuming it isnt connected with other prob'.
even more simple, possible just getting a bit old and rusty.
Try a bit of 3 in 1 on the key, insert it, wiggle it about and give it time to penatrate.
Worked for me :y
It's amazing how a bit of lubricant, can get thing going again. [smiley=shocked.gif]
« Last Edit: 24 November 2006, 01:50:41 by Boiler_Man »
Omega 2.0 DTI GLS Estate 99 Gold & Omega 2.2 DTI CDX Estate 03 Silver. Just need a Bronze one now for the full set.
Peanuts
« Reply #7 on: 24 November 2006, 12:44:51 »
Thanks for all the input guys, yest have tried the obvious thanks anyway. only have one key.  Will try all the advice given.
Regards.
Peanuts
HI2DVY
  • Deepest Darkest, Scotland
« Reply #8 on: 24 November 2006, 14:51:18 »
...or the even more obvious... are you sure it's in "Park". Key won't turn otherwise.
some day.....
« Reply #9 on: 24 November 2006, 18:06:32 »
:-? It'll turn what ever position the gear selector is in - it just doesn't do anything unless you're in P or N. Mines been forced in the past as I can get the key out of the ignition when not in P
Peanuts
« Reply #10 on: 24 November 2006, 19:13:45 »
The Steering is in lock, but no matter how much I try, it wont move. have done the WD40 letting it soak untill morning. fingers crossed.
Thanks all.
Peanuts
Markjay
  • London
« Reply #11 on: 25 November 2006, 00:02:58 »
Thanks all.
Peanuts
..you tried wobbling the locked steering wheel violently (well, not too violently…) from side to side while working the key…?
« Last Edit: 25 November 2006, 00:03:34 by markjay »
« Reply #12 on: 25 November 2006, 01:37:48 »
Had the same problem on my mates Elite, it was me that posted it up a while ago..
If you can't get it undone you need a new barrel etc + housing if the steering is locked.
About £80 from the dealer all in.
You will need to tap round, or otherwise remove the 2 shear bolts holding on the assembly.
It's fiddly, but easy enough, and solves the prob!
ricardo1500
  • Wolverhampton
« Reply #13 on: 25 November 2006, 19:01:26 »
Hi Peanuts
This may sound like a daft suggestion but have you tried the key both ways up?? One of my 2 keys will only turn the ignition on one way up!!
Rich
