Author Topic: lpg - loss of a spare legal ?  (Read 6837 times)
tommoynihan
« on: 23 November 2006, 16:38:49 »
I'm just about to join the Omega owners club with a 2.2 CDX.
I'm still planning to go lpg, possibly with a toroidal tank, but I have 2 questions :
1.    Is is it illegal not to carry a spare wheel, and just use an aerosol ?
2.    Is it really impossible to change the bulbs in the n/s light cluster if a toroidal tank is fitted ? Can you fit led bulbs that should rarely fail ? (and where from ?)
Thanks,
Re: lpg - loss of a spare legal ?
« Reply #1 on: 23 November 2006, 16:46:39 »
Martin Imber is your man.......and no, its not illegal to have no spare wheel (most sports cars have no spare).
Can't comment on the bulb replacement......
« Reply #2 on: 23 November 2006, 16:49:56 »
The tank is same size as spare wheel and goes in same place - and you need to remove this to get bulbs out.....
Eliteman Steve
  • Brighton
« Reply #3 on: 23 November 2006, 19:28:59 »
Don't need to carry a spare , but if you do it must have legal tread depth and must be inflated to the correct pressure , otherwise the "old bill" can do you! Seems a bit strange realy. :-? :-?
philayl
  • Wirral, Merseyide
« Reply #4 on: 23 November 2006, 20:03:01 »
Hi, I tried using LED bulbs in my rear lights, it was not a success, the MID display kept telling me there was a fault on the lights, I tried fitting ballast resistors to each bulb to stop this. It did stop the messages on the display, but the resistors were getting hot enough to fry an egg on,  I removed them very quickly and put the old bulbs back in, end of experiment.
Ken T
  • Stockport
« Reply #5 on: 23 November 2006, 22:37:40 »
Hi there,
I too have been thinking about LPG, (just got the kit today but that's another story) and Mark DTM is right, there is no room to do a normal bulb replacement. However, I was wondering if it wouldn't be possible to undo the 4 nuts holding in the actual light housing and thus pull it out of the body, and thus be able to replace the bulbs. I haven't tried it yet but.... Also another thought, what shape will your tank be?. The rear wing has been shaped to hold a spare tyre which is a certain shape. Now, some toroids on sale have a rounded shape, others are more cylindrical with rounded edges, so although they may be the same radius and width, they might not fit!. I asked a question re LPG recently and someone sugested Tinley as a good source of parts. I had a quick chat with him and he 'Might' let you try some of his tanks before buying ( if suitably chatted up first). If you look at Gascarco.com photo galleries there is an Omega with a tank in the spare wheel arch. There is no mention if he was able to change the bulbs after ;D
Cheers Ken
Ghosts in my machine
  • Derby
« Reply #6 on: 24 November 2006, 13:24:55 »
I often take the spare wheel out for the MoT. If its in there, they can fail you on it. If its not then its not a problem.
Never used that tyre weld stuff, but I know someone with a Range Rover who used that type of tank on an LPG conversion and was happy to replace the spare with a couple of tins of tyre weld and reckons it works okay.
Dyslexic dwarves.... there not big and they're not clever!
mijfife
  • Rosyth, Fife. Scotland
  • AAARRRRGGGGGGGGG, IT'S WAS ONLY A GLS!!!!!!!
« Reply #7 on: 24 November 2006, 17:35:36 »
I've got a tin of the tyre weld that I keep in the car and I also bought a space saver to chuck in the back.
Cheers Jim
The fleet consists of a Singer Chamois Coupe, an Imp based kit car - BS Nymph, and a Kawasaki GPZ 900R (& a Toyota RAV4 LPG for the work horse!)
« Reply #8 on: 24 November 2006, 18:28:37 »
Some Jags (and possibly others) come with a rather nifty spare idea - its a compact inflatable wheel and a compressor.  Not sure if I fancy driving far on a rubber ring though...
Markjay
  • London
« Reply #9 on: 24 November 2006, 23:41:48 »
...so if you get stopped for a spot-check and your spare if naff, all you need do if lift the boot lid, take out the spare and throw it as far away as you can shouting 'now who's rubbish is this?' then turn to the constable and say 'good evening officer, I don't actually carry a spare, this was just a piece of junk someone forgot in my boot'...  :o
Alas, no more Omegas....
Taxi_Driver
« Reply #10 on: 25 November 2006, 09:39:37 »
Cheers Jim
I tried a tin of tyre weld once.....didnt work  :( but then maybe i didnt use it correctly, i was told afterwards you are suppose to jack the car up first, which i didnt  :-/
And the tyre place wasnt impressed they had to clean out a tyre full off white gunk before they could repair the tyre!
Ive got a space saver in the boot now  :y
mijfife
« Reply #11 on: 25 November 2006, 15:17:20 »
My worry with only having the can of goo was what if you had a blow out rather than just a puncture? At least the space saver is ready to fit and should definitely get you home  :)
« Reply #12 on: 25 November 2006, 15:48:47 »
My worry with only having the can of goo was what if you had a blow out rather than just a puncture?  .....
You'd be up a certain creek without a paddle!  ;)
Taxi_Driver
« Reply #13 on: 25 November 2006, 15:56:38 »
Or waiting for the AA to show up several hours later like i did  ::)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #14 on: 25 November 2006, 17:16:44 »
Did he bring you a cam sensor?  ;D ;D ;D
TuBy's new whipping boy.
