Author Topic: All Steamed up!!!  (Read 18256 times)
Eliteman Steve
  • Brighton
Re: All Steamed up!!!
« Reply #45 on: 22 November 2006, 22:41:48 »
Had an MGB years ago with same problem , turned out to be the heater matrix leaking slightly so on de-mist it blew water vapor all over the front screen , which then condensed on the cold glass :D!!! Driving was prety much guess work :o :o :o!!!!
Boiler Man
  • Sale, Manchester
« Reply #46 on: 23 November 2006, 01:15:59 »
Very Good point, if all else fails, that could be a possible.
never thought of that one. Is it losing coolant?
good thinking Batman
errrr, sorry I mean Eliteman  ;) (sorry seventies thing)
ps. mind you if you drove an MGB you will proberbly remember the seventies ;D
« Last Edit: 23 November 2006, 01:18:40 by Boiler_Man »
Omega 2.0 DTI GLS Estate 99 Gold & Omega 2.2 DTI CDX Estate 03 Silver. Just need a Bronze one now for the full set.
Eliteman Steve
  • Brighton
« Reply #47 on: 23 November 2006, 19:13:52 »
Certainly do :y! And I've got the platforms and flares to prove it ;D ;D ;D
sir moanalot
  • fens
« Reply #48 on: 25 November 2006, 16:29:50 »
hi all, screen clears well when window open slightly or sunroof open on 1st/2nd tilt. when its not bucketing down will certainly check out pollen filter base is not containing a paddling pool.
« Reply #49 on: 25 November 2006, 16:35:36 »
Assuming pollen filter not really damp, it may be purely just the amount of dampness it car.  Try ensuring the vent in boot is clear (this will help better airflow through car, and help reduce amount of humidity in car), but also keep opening roof/windows when possible to also assist until it stops doing it...
« Reply #50 on: 25 November 2006, 18:35:16 »
Note, the vent in the boot is in the off side rear quarter behind the cover by the rear lights (and hence the earlier comments!)
STMO123
« Reply #51 on: 25 November 2006, 18:50:40 »
So, how much crap do you have in the drivers side boot bin by the tail lights.....?
Eye-opener! Penny drops! Doh!
mijfife
  • Rosyth, Fife. Scotland
  • AAARRRRGGGGGGGGG, IT'S WAS ONLY A GLS!!!!!!!
« Reply #52 on: 25 November 2006, 21:06:39 »
Does the estate have any vents at the back and if so, where are they?
Cheers Jim
The fleet consists of a Singer Chamois Coupe, an Imp based kit car - BS Nymph, and a Kawasaki GPZ 900R (& a Toyota RAV4 LPG for the work horse!)
« Reply #53 on: 25 November 2006, 22:17:56 »
Cheers Jim
I would guess same area, but do not know for def...   ...it will defo have some vents - all cars do...
Pages: 1 2 3 [4]  All   Go Up
