Author Topic: Pollen filter drain blocked  (Read 6477 times)
markrl
  • London
« on: 03 December 2006, 18:17:43 »
Anybody know the best and easiest way to unblock the drain hole underneath the pollen filter housing. I managed to find a nice large reservoir of water up to the bottom of the pollen filter which I have siphoned out. Below this a large amount of accumulated silt covering the rubber bung which I presume is where the water should drain out. Despite a bit of prodding it still appears blocked  :'(. Is this rubber bung the top of a tube ? and can it be removed for cleaning ?  Any suggestions from others previously afflicted with this problem gratefully received.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Pollen filter drain blocked
« Reply #1 on: 03 December 2006, 18:37:18 »
Don't know much about the 3.0 but as far as I'm aware, there is a drain tube under the rubber bung.
I like red cars
STMO123
« Reply #2 on: 03 December 2006, 18:59:57 »
Get your hand in there and, if necessary, take the bung out. Give everything a good clean and rinse it through. IIRC the bung should have a tube attached or as part of it, this should point towards the front of the car when replaced.
Richard A
  • Aldridge, West Midlands
« Reply #3 on: 03 December 2006, 21:01:03 »
Don't attack the 'bung' it is water tight and that is how you want it to be !
The out spout for the water is under the front near side wing, with the road wheel on full right lock look under the wing, you should see a black rubber flap just beteen the spring and the rear of the arch, lift the flap, it will be full of crud, rotting leaves, once cleared check ever month.
richard a
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #4 on: 03 December 2006, 21:04:31 »
Is that on the facelift or pre-facelift?
TuBy's new whipping boy.
« Reply #5 on: 03 December 2006, 21:32:47 »
Earlier cars only, later drain into engine bay...
STMO123
« Reply #6 on: 03 December 2006, 21:41:47 »
I attacked my bung! Had to. It was so scummy and yucky in there I couldn't make out what was going on. Seemed to go back OK :o
rogerreno
  • Deepest darkest Coalville
« Reply #7 on: 03 December 2006, 21:46:16 »
I attacked my bung!
That reminds me of the bit in Beavis and Butthead do America when he's on about TP for his bunghole!!!
Cracks me up everytime I see it... ;D ;D
Elwood: It's a 106 miles to Chicago. We got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Jake: Hit it!  8-)
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #8 on: 03 December 2006, 21:52:43 »
Bungholio  ;D ;D classic.
madmatt
  • Stevenage, Herts
« Reply #9 on: 03 December 2006, 22:04:19 »
I have to confess that when my pollen filter compartment filled up last winter, I was a little naughty and used the car vac at the local Morrisons and drained it with that, then quickly left the scene!!!!
The Car Vac made a rather interesting noise!!!!!
Never Lie, cheat or steal......the government hates competition!
EddieX
  • Halstead Essex
« Reply #10 on: 03 December 2006, 22:11:07 »
My '99 drains into engine bay. When I bought the car, the bung (it looks more like the scuttle drain really) wasn't even in place. By the time I finnished replacing it, my forearm looked like I'd been self harming  :'( And I'm not much bigger than CaptainZok's boy. :D
Hope you're skinny Mark.  ;D
« Last Edit: 03 December 2006, 22:16:25 by EddieX »
"Onwards and Downwards"
hotel21
  • The Kingdom of Fife
« Reply #11 on: 04 December 2006, 12:18:38 »
So it was you!!!     [smiley=angry.gif]   Bandit.....    ;D  Good idea, just check for the CCTV and the number plate reading kit!
hotel21
« Reply #12 on: 04 December 2006, 12:20:52 »
I used the pressure washer lance into the bottom of the skuttle, where the bung is.
Then went upstairs to get washed looking like an extra from a Carry On sketch with the backwash all over my coupon   :-[  And its smelly..... :o
« Reply #13 on: 04 December 2006, 12:35:22 »
i just get my hand and arm down there, and clear it out.
Get a hose on jet setting push that down with your hand and guide it so its directly over the blocked hole and turn the hose on... ware wellies though!
Also park up with the wheel on full left lock, get behind the wheel and poke around the exit pipe, i had to do that for my project A... was messy business but got it clear in the end  :y
« Reply #14 on: 04 December 2006, 13:29:00 »
Yes, you just need a Tunnie, every tool kit should have one, just drop it in, give him a small spoon and wait for it to be cleaned out  :y.
I actualy use some hefty cable and poke it through the drain and then flush through.
