Author Topic: Intermittent Miss.  (Read 2396 times)
Pete Elite
  • Uxbridge, Middlesex
Intermittent Miss.
« on: 08 December 2006, 01:06:42 »
Hi all,
       My 96 3.0L  Elite has got an intermittent miss.
 On tick over it's fine and if you use light throttle movements it builds up speed ok but as soon as you rapidly increase throttle it misses badly.
 This lasts for some time at which point you could throttle her up and it fine again.
 Any ideas as to the probable cause :question.
 Cheers,
           Pete :).
Re: Intermittent Miss.
« Reply #1 on: 08 December 2006, 01:17:40 »
Remove and check each plug lead, one by one, and make sure there's no oil in the plug wells. A very common cause of intermittent misfires!
Markjay
  • London
« Reply #2 on: 08 December 2006, 07:46:57 »
Also - spark plugs problems, air/vacum leak, blocked fuel filter, dirty injectors...
Alas, no more Omegas....
« Reply #3 on: 08 December 2006, 09:25:48 »
Also make sure the spark plugs are torqued down properly
omega si
  • Leeds, West Yorkshire
« Reply #4 on: 08 December 2006, 10:08:50 »
Sounds pretty similar to my 2.5  :'(
Gonna have a good look at the mutha this weekend if the weather will let me
« Reply #5 on: 08 December 2006, 19:54:55 »
DIS unit? Crank sensor?
JasonH
« Reply #6 on: 08 December 2006, 21:19:15 »
My money would be on HT leads....
Pete Elite
« Reply #7 on: 08 December 2006, 21:33:58 »
 Thanks for all your replies.
 Will have a good looksee.
         Cheers,
                   Pete :y.
