Author Topic: Intermittant ABS TC and speedo fault?  (Read 12578 times)
Re: Intermittant ABS TC and speedo fault?
« Reply #30 on: 27 November 2006, 18:58:00 »
I could take the ABS ECU off my donor car for you if it's the right one, but I've never taken one off before...
need to check ident code...
prolly also need tech2 to correct config variants...
Would it have 2 be the same engine :-?
For variant code, probably. I would need to check what variant options there are, but its cold and dark out there now...
« Reply #31 on: 27 November 2006, 19:11:17 »
Don't go out there on my behalf m8 bit of a chill i  the air
« Reply #32 on: 27 November 2006, 19:23:33 »
I wasn't going to  :P
 ;D
« Reply #33 on: 27 November 2006, 19:44:35 »
 ;D
 ;D
paulr
  • Frodsham
« Reply #34 on: 28 November 2006, 18:36:16 »
Just started having this problem on my 2001 omega abs and tc lights come on and speedo dies. Which sensors do I need to check?
« Last Edit: 28 November 2006, 18:36:39 by paulr »
STMO123
« Reply #35 on: 28 November 2006, 18:38:44 »
ABS sensors. Either side of the diff on rear axle
paulr
  • Frodsham
« Reply #36 on: 28 November 2006, 21:13:12 »
ok thanks, guess I need to do a bit of praying
« Reply #37 on: 29 November 2006, 19:11:22 »
Would a fault like this affect MOT?
If it happened during testing, yes.
How will it affect the MOT?
« Reply #38 on: 29 November 2006, 19:15:12 »
It will be the difference between a years ticket, and one of those nasty fail tickets.
« Reply #39 on: 29 November 2006, 19:16:40 »
 ;D but the speedo doesn't come into the MOT
« Reply #40 on: 29 November 2006, 19:17:23 »
But the abs does...
paulr
  • Frodsham
Re: Intermittent ABS TC and speedo fault?
« Reply #41 on: 03 December 2006, 22:48:34 »
LSG 1 did you have a look at your sensors and plug at abs unit? Also for anyone, had a problem with cdc safe on my radio which I still have but I took my radio out and have basically had this problem since just after that, also my rear passengers side electric window has stopped working. Now is the abs tc speedo thing a coincidence or could I have disturbed something around the radio that could have give me the abs tc speedo problem and rear window problem? Also have lost power steering a couple of times when starting the car then it just starts working again within a minute
« Last Edit: 03 December 2006, 23:06:18 by paulr »
« Reply #42 on: 04 December 2006, 21:47:38 »
As i didn't get around to it last week i'm gonna try this week lol ;D will keep you posted though m8 :y
« Reply #43 on: 04 December 2006, 21:49:38 »
BTW as with Paul R my steering goes heavy sometimes  :-?
« Reply #44 on: 04 December 2006, 21:50:44 »
But the abs does...
Also TB ABS only stops the brakes locking up but with older cars that don't have ABS they can still pass so how does this work :-?
Pages: 1 2 [3] 4  All   Go Up
