Pages: [1] 2 3  All   Go Down
Author Topic: 2.5 v6 missfire  (Read 11420 times)
omega si
  • Leeds, West Yorkshire
2.5 v6 missfire
« on: 07 December 2006, 22:56:57 »
Right here goes!
engine has got an intermittent misfire. most of the time its fine, other times its maybe got a slight miss on tickover but noticably so when revved up.
The story so far is that I recently replaced a knock sensor (drivers side) where the wire had got squashed. E/m light on and all that. Note though that it still had the occasional miss before i did the knock sensor. thought it might be due to the air mass sensor, so i got a second hand one off ebay as it was going cheap (thought it wouldnt harm to have a spare either way) but changing it has made no difference.
The car has had the dis pack, leads and plugs done May 2005.
Its a real pain to diagnose tho, no e/m light and only comes on for a bit (usualy when im at work and the wifes using it).
I was planning on checking the induction system for leaks, then pop the plenum chamber off and check sparks. Anyone got any ideas if this is the best plan or where i should start my investigation??
Cheers
Si
Markjay
  • London
Re: 2.5 v6 missfire
« Reply #1 on: 07 December 2006, 23:11:21 »
Welcome to the forum omega si.
Which engine (2.0-8/2.0-16/2.2/2.2DTI/2.5/2.5TD/2.6/3.0/3.2/), year, and mileage....?
Did you check for engine error codes?
Missfire can occur for many reasons, DIS ot HT could have gone again, leaking rocer cover gaskets can flood the plug wells, leaking or disconnected vacum pipe, clogged fuel filter, injector problems, and more...
Either way don't drive the car with a missfire, the cats don't like raw fuel!
Alas, no more Omegas....
Markjay
  • London
Re: 2.5 v6 missfire
« Reply #2 on: 07 December 2006, 23:14:07 »
Also - if EML came on, check for error codes before doing anything else.
Do not check for spark - this is seriously high voltage, not like the old days where you could simply hold the HT lead away from the plug...
omega si
Re: 2.5 v6 missfire
« Reply #3 on: 07 December 2006, 23:35:48 »
Error codes have been checked.
Had shown a low voltage on the air mass sensor but wasnt present at the time, and it only happened once.
By the way its a petrol 2.5 v6 petrol auto and done 92k.
Fired it up tonight and its purring away nicely.
Gonna test the ht by removing the fuel injector multi plug, pulling a lead off one plug at a time and then using a spare plug, check for a spark holding it a few mm away from the block (with insulated pliers) Should be okay doing this right?
Also, had the near side rocker gasket leak last year some time after the dis pack was replaced. But sorted it and all was fine until now. Its all dry as a bone up there at the mo.
Re: 2.5 v6 missfire
« Reply #4 on: 07 December 2006, 23:59:31 »
DONT DO IT - PLEASE.
For Two reasons.
1) Modern engine management systems carry VERY high current through the ignition leads, I had such a hell of a belt off an omega doing this, and I had rubber gloves on!! Learn from my experience, - bad move.
2) It will easily goose the DIS pack by getting it to spark when the plugs not installed into the car.
Please trust me on this one mate.
You say you had ONE rocker cover gasket done? Why only one? I would have thought it was only good practice to do both, if you're going to go to the trouble of getting the pleunum/trumpet off to do one.
Although you had the gasket done, did you have the FULL breather system cleaned? And did you use a genuine VX gasket? Both very important points. If breathers were not cleaned, it could easily have blown again.
Unfortunately you need to go back to basics before looking too far. I would recommend starting with a cold engine, and removing each plug lead one by one, checking the condition and cleanliness of the contacts. Make sure there is no oil in ALL of the plug holes.
Then look at the condition of the plugs.
From experience, I reckon you will find a lead that's split somewhere. On mine, it was Cyl 6. It was split up the shank of the lead, and caused me an intermittent miss, Just like you describe!!
Tip = if checking for spark, I attach a timing gun to the lead in question to see if it's firing. you won't be able to see anything re. the ignition timing this way, but you WILL See a spark.
Where are you located? If yu're local I can lend a pair of hands to do this.
omega si
Re: 2.5 v6 missfire
« Reply #5 on: 08 December 2006, 09:11:26 »
 Thanks for the offer mate  , but I'm in Leeds. Probably a bit too far for you.
Can you explain more regarding the breathers as I'm not sure what you mean here?
Re: 2.5 v6 missfire
« Reply #6 on: 08 December 2006, 09:24:25 »
Hi Si and welcome :y
For cleaning the breathers try this
http://www.omegaowners.com/forum/YaBB.pl?num=1152598350 :y
omega si
Re: 2.5 v6 missfire
« Reply #7 on: 08 December 2006, 10:00:39 »
Cheers Pete
Re: 2.5 v6 missfire
« Reply #8 on: 08 December 2006, 17:13:33 »
Couple of general (very general) pointers on v6 misfires:
Read codes, and fix any codes present.
Codes relating to MAF are frequently an air leak or egr problem.
No codes is often an HT problem.
omega si
Re: 2.5 v6 missfire
« Reply #9 on: 08 December 2006, 18:50:25 »
Thanks for that. Is there anything I should be looking out for with the egr valve?
Just started stripping a few bits off ready for tomorrow and found oily deposits in the air pipe between the large induction pipe attached to the throttle body and the idle air control valve.
Is this normal? Is this related to cleaning out the breathers?
Cheers
« Last Edit: 08 December 2006, 18:51:24 by omega_si »
Re: 2.5 v6 missfire
« Reply #10 on: 08 December 2006, 19:07:36 »
Cheers
Sounds like throttle body, as well as breathers, could do with a bit of a clean...
Re: 2.5 v6 missfire
« Reply #11 on: 08 December 2006, 19:14:33 »
the crud in the pipes is normal, its just a build up over time. My 2.2 was almost completely blocked, cleaning it out gave a noticeable MPG and performance increase.
Might also be worth checking the leads, and check all the connections on the DIS Pack are good.
Has the engine ever had an oil cooler fail or any other problems before this misfire appeared?
omega si
Re: 2.5 v6 missfire
« Reply #12 on: 08 December 2006, 20:49:48 »
No, nothing like that. It started playing up around the same time as the drivers side knock sensor but I dont think that should affect anything should it?
Cheers
omega si
Re: 2.5 v6 missfire
« Reply #13 on: 10 December 2006, 12:13:41 »
Just an update for anyone else having similar problems.
Rocker gasket on drivers side needed replacing, plugs were soaked in oil.
That done I removed the leads and dis pack. Dis pack seems to be the problem, or at least one of them! No6 terminal is badly corroded (all the rest look like new!).
So i guess im looking for a dis pack now if anyone knows a good place to source
And does anyone have a clue why just one terminal should have done this? It was replaced in may 2005.
Cheers
Si
Re: 2.5 v6 missfire
« Reply #14 on: 10 December 2006, 12:21:33 »
Cheers
Si
Has it had a squirt of coolant from hbv?
You sure DIS is knackered? Misfire not caused by oil in plug wells?
Pages: [1] 2 3  All   Go Up
