Author Topic: Power steering hard work.  (Read 2626 times)
Big Rod
  • Fife, Scotland
« on: 16 December 2006, 19:28:34 »
SWMBO's Elite's steering appears to be becoming harder to steer. I'm used to my MV6 being able to basically 'whirl' the steering wheel round using little more than my pinkie, but the Elite's very hard work even when moving.
There is a bit of a slow puncture in one of the front tyres but that gets topped up frequently.
Any suggestions?
« Last Edit: 16 December 2006, 19:29:00 by Big_Rod »
If I have to explain you won't understand!
Admin
Re: Power steering hard work.
« Reply #1 on: 16 December 2006, 19:40:20 »
I would check the easy ones first.
The fuse (also on the same circuit as electric seats as I recall)
Aux belt tension.
Power steering fluid level/condition.
After that it is a case of the PAS pump or the assistance solenoid (tech II required to confirm).
The Administrator.
Big Rod
  • Fife, Scotland
« Reply #2 on: 16 December 2006, 20:55:46 »
Yeah, kind'a figured that'd be the case!!
It's due a service, so I'll get them to replace the fluid first to see if that'll help.
Cheers Dave!!
Taxi_Driver
« Reply #3 on: 16 December 2006, 21:32:55 »
My Power steering is heavy....well i think it is.....TB says not adjustable on a 2.2 with tech2....i assume bigger engines are adjustable with tech2....maybe worth seeing if it can be made 'lighter' with a tech2? :-/
« Last Edit: 16 December 2006, 21:33:26 by Taxi_Driver »
« Reply #4 on: 17 December 2006, 10:08:28 »
ZF Servotronic system fitted to V6 have 3 settings for amount of assistance, and is set with Tech1/Tech2 depending on age...
