Author Topic: EMERGENCY HELP NEEDED PLEASE  (Read 15762 times)
rpont
  • Tadcaster
Re: EMERGENCY HELP NEEDED PLEASE
« Reply #30 on: 14 December 2006, 12:32:48 »
OK, well that turned my knowledge of the V6 Upside down.. i thought it was, the one at the bottom of the block, at the front, below the lower pulley...  :-?
What is that one then - I assumed it was there, as it's near the CRANK, not the CAM..... :)
Cheers.
Matt
The one with the wire coming out towards the front? That's the oil pressure switch.
Omega-MV6
  • Calne, Wiltshire.
« Reply #31 on: 14 December 2006, 13:32:44 »
Thankyou.. that answered my question nicely...  :)
Cheers.
Matt.
PS: Cool Smilies...  ;D
There are only 10 types of people in the world.....
......Those that understand binary, and those that don't
mar892ree
  • Northampton
  • if it dont undo, hit it wiv an hammer
« Reply #32 on: 14 December 2006, 16:43:26 »
Mines been playing up for a while, but different syptoms !
Sometimes car will crank a few times before firing, but little engine electrics light comes on !
Turn car off, re sart and its fine !
Car will always start, and even exceed 3000rpm, with light on , so from what i have been told the car isnt in limp mode !
This fault only occurs at random intervals, as i'm not in a hurry to replace the crank sensor, after Taxi Drivers description of its removal etc ! on a 2.2
So woulld anyone like to diagnose these sypmtoms on my 2.2 ! I was told before it might be crank sensor too, but the symptoms are slightly different !
Mark
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #33 on: 14 December 2006, 16:57:41 »
According to my sources (well I looked it up on the Internet...) the Crank Sensor for the 3.0L was different than that of the 2.5L, but it is the same one later used on both the 2.6L and 3.2L.
Crank Sensor 2.6/3.0/3.2 Vx P/N 90540743:
Crank Sensor 2.5 Vx P/N 90492006:
Though strangely they both look the same....
the only (slight) difference I can spot is that the top one appears to have rounded corners on the plug whereas the lower one the edges are pretty much square. Not a huge difference! Maybe the pin assignment is slightly different too ???
« Reply #34 on: 14 December 2006, 18:55:25 »
Mark
If you are getting EML on, you should be able to get the codes read, which would be a real clue ;)
mar892ree
  • Northampton
« Reply #35 on: 14 December 2006, 21:10:16 »
I know Jamie !
Just that i'm such a lazy git , erghhhhhh mean i'm so busy, i havent managed to get time to come over to you as you live soooooooooo far away in Brackly  LLOLL
Perhaps after Xmas then !
I was toying with the idea of having Cruise fitted too, kill two birds with one stone as it were !
Which stalk am i looking for off of EBay !! Left or right as i am sure i have seen both with exta buttons !
Also as i have a face lift i presume i have to have a stalk ( which ever one ) taken from a face lift donor car !!
Mark
« Reply #36 on: 14 December 2006, 22:01:08 »
I know Jamie !
Mark
Stalk, I would buy new, around £30 +VAT.  If you get 2nd hand, ensure its the 4 wire one, not the 2 wire one for 2.5TD
mar892ree
  • Northampton
« Reply #37 on: 14 December 2006, 22:23:23 »
Cheers Jamie, will do ( buy new) as i now have my trade account sorted !
Can you please explain ( in idiots english) as to how i can spot if i have the brake/clutch switch fitted on my car, what am i looking for ( if indeed its already fitted )
Cheers
Mark
« Reply #38 on: 14 December 2006, 22:25:43 »
Cheers
Mark
If its an auto, it will have right switches on your facelift 2.2.  If its an auto, you'll need to look - you'll see the brake switch, clutch should have a similar switch which clips into the metalwork around it...
mar892ree
  • Northampton
« Reply #39 on: 14 December 2006, 22:30:52 »
Being a manual, your saying if there fitted the swicths will be obvious !
How far up the pedal will they be, above that silly foam filled panel i suppose !!!
« Reply #40 on: 15 December 2006, 14:59:49 »
yes, remove the card/foam panel.  Look up and you will see brake one just below where pedal pivots.
hotel21
  • The Kingdom of Fife
« Reply #41 on: 15 December 2006, 16:36:09 »
This is what you should see under the foam sheet when its removed.
Heres the 4 pin brake switch in position
and the clutch switch.
Hope this helps
B    :y
Markjay
  • London
« Reply #42 on: 15 December 2006, 17:49:25 »
Hope this helps
B    :y
TD note, I have a competitor picture poster....  ;D
Nice pics Hotel21  :y
Alas, no more Omegas....
mar892ree
  • Northampton
« Reply #43 on: 15 December 2006, 22:54:22 »
perfect thanks for the pics
Nick
  • Essex
« Reply #44 on: 16 December 2006, 08:14:57 »
so to clarify, the crank shaft sensor is next to the oil filter
cheers nick
Pages: 1 2 [3] 4  All   Go Up
