Pages: [1] 2 3  All   Go Down
Author Topic: Worthwhile upgrades?  (Read 8872 times)
Essex_Andy
  • Have a guess?
« on: 29 December 2006, 17:52:39 »
Just browsing on E-Gay as you do and found a couple of rear sunscreens as well as crusie modules and stalks for my 1998 model.
(I think on the mini-facelift 1998 models cruise is just a plug a play affair, no ECU re-programming though please correct me if I have been given duff info)
The 'spare' lead(s) inside the left side of the boot, are they the power leads for the sunscreen?
and as for cruise I have been told and read that the module/actuator lives on the inner wing but I cant find the harness connector....will it be lurking under the windscreen scuttle/tray?
Any help greatly appreciated.
Still waiting for late Jan early Feb to fit the 3.0 cams. Ride is good on the new irmscher springs and shocks. Need to go back to Wheels In Motion soon for the 2000mile final fine tune.
Also probably looking for a set of 17" or 18" rims...but cant find any in sensible money....most seem to be cicra £700+
If an artic overtakes you, you're driving too slow!!!!!!!!!!!
Re: Worthwhile upgrades?
« Reply #1 on: 29 December 2006, 17:54:32 »
Cruise loom is bolted to top of drivers side front suspension turret.
Rear blind loom is a 3 pin plug, up under shelf on left hand side...
Essex_Andy
  • Have a guess?
« Reply #2 on: 29 December 2006, 17:57:50 »
Thanks fella
I just cant find the wiring plug that goes to the cruise 'doofer' that bolts to inner wing/strut turrett
« Reply #3 on: 29 December 2006, 17:59:16 »
Thanks fella
Quite big, 10 pin plug, some people confuse it for the diagnosics plug....
« Reply #4 on: 29 December 2006, 17:59:52 »
Take a piccy of your engine bay, and post it here....
Essex_Andy
  • Have a guess?
« Reply #5 on: 29 December 2006, 18:24:31 »
Will do tomorrow...bit dark now :y
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #6 on: 29 December 2006, 18:24:37 »
i have a working cruise unit for a miggy with cable as well, PM me if interested.....
Sorry for thread hijack
« Reply #7 on: 29 December 2006, 18:27:51 »
Remember, the stalk needs to be the 4 wire stalk (about £30 +VAT new, not worth buying 2nd hand).
I seem to recall the cruise throttle cables are different between the different engine sizes...
Martin_1962
« Reply #8 on: 29 December 2006, 18:45:32 »
LEss than that from Autovaux
« Reply #9 on: 29 December 2006, 18:48:55 »
inc p&p?
Essex_Andy
  • Have a guess?
« Reply #10 on: 29 December 2006, 20:16:11 »
PM sent
Martin_1962
« Reply #11 on: 29 December 2006, 20:37:27 »
inc p&p?
I think so
« Reply #12 on: 29 December 2006, 20:42:44 »
inc p&p?
I think so
Worth knowing, esp if they are brand new, and not recon stuff should by other companies. Recon ones don't last (assuming they work at all)
rpont
  • Tadcaster
« Reply #13 on: 29 December 2006, 20:54:02 »
Here's a picture of where it should be sitting. It's the plug between the turrett and the brake fluid bottle.
« Last Edit: 29 December 2006, 20:54:54 by rpont »
« Reply #14 on: 29 December 2006, 21:13:46 »
Also, the cruise unit is the cube shaped unit under brake reservoir, to left of exhaust in that piccy...
« Last Edit: 29 December 2006, 21:14:16 by TheBoy »
Pages: [1] 2 3  All   Go Up
