Author Topic: Ive discovered why my 2.2 has been missing  (Read 15569 times)
Taxi_Driver
« on: 28 December 2006, 12:48:16 »
In another thread i mentioned my 2.2 has been missing when cold on lpg.....and said i was going to change the plugs........well this morning i started to change em.....took em out....and now i dont know what to do.......coz this will be the reason for the missing.....
The very covered in oil plug  :'( was the second one back from the front.
Any suggestions ?? HELP
Markjay
  • London
Re: Ive discovered why my 2.2 has been missing
« Reply #1 on: 28 December 2006, 12:51:37 »
Was there oil on the tip of the plug, or did it get contaminated when you pulled it out?
If only on the outside, then look for the leak and fix it.... if the tip was oily, this is not good news, compression test would be the next stage.
Also, was the oily plug loose compared to the others?
Incidentally, the other three seem to be running a bit lean - is this because of the LPG?
« Last Edit: 28 December 2006, 12:53:29 by markjay »
Alas, no more Omegas....
Phil
« Reply #2 on: 28 December 2006, 12:52:22 »
First suggestion is you should NEVER start and run a car from cold on LPG.
It dries out the heads and causes alot of damage, which it would appear is going your way.
This is why a decent LPG conversion will always start on petrol and 'flip over' once warm
Taxi_Driver
« Reply #3 on: 28 December 2006, 12:58:50 »
The tip was oily......ive check the coil pack and theres no oil on the outside of the rubber sleeve only on the very end of it......so suggests to me oil has come from inside to me  :-/
« Reply #4 on: 28 December 2006, 13:00:53 »
Not necessarily....  ....I would still be looking for an oil leak around the head...
Taxi_Driver
« Reply #5 on: 28 December 2006, 13:01:14 »
It doesnt start on lpg.....it starts on petrol.....and auto switches to lpg when water temp is about 40C......it when this temp it misses on lpg ....when it gets to 70+ its ok
Taxi_Driver
« Reply #6 on: 28 December 2006, 13:03:40 »
None of them were 'tight' tight but none were loose either
And yes probably is because of lpg the other plugs look like that
Martin_1962
« Reply #7 on: 28 December 2006, 13:36:42 »
YEs he has same issue as me - lean running on gas
Taxi_Driver
« Reply #8 on: 28 December 2006, 14:06:41 »
Here are some pics looking down the plug wells....
Plug well nearest the front ...and looks pretty oil free to me
This the one with the oily plug in it
And the rest are diffent pics of the rest of the plugs wells
So im assuming a gasket is on its way out?  :-/
Could this be caused by blocked breathers?  :-/
Martin_1962
« Reply #9 on: 28 December 2006, 14:20:49 »
Rocker cover gasket, don't forget the o rings, also clean the breathers
Taxi_Driver
« Reply #10 on: 28 December 2006, 15:09:37 »
Is this what i should be doing then?
http://www.omegaowners.com/forum/YaBB.pl?num=1152565472
If so ive read through it, and think i can follow it.
Just need the part no's for the gasket and o rings and sealant
And need to get myself a torque wrench  ;D
« Reply #11 on: 28 December 2006, 15:29:55 »
Funny thread this.....seen this one before......
Shall I tell you the answer......or does anybody want to continue guessing incorrectly....
Taxi_Driver
« Reply #12 on: 28 December 2006, 15:38:59 »
Any easy answer please Mark  :y
« Reply #13 on: 28 December 2006, 15:45:51 »
I suspect its a nasty case of KHMS......Kack Handed Mechanic Syndrome ;)
The small quantity of oil in a plug near to the oil filler cap is a classic miss the cap slightly when filling it symptom....
The shots suggest its not cam cover gasket and the breathers are clear (seem to recall them being cleared out in the past) and hence the small amount around number two which indicates possibly a right handed person (would have the can over the cam cover when pouring).
As for the oil coming from the bore.....if the plugs not a gas tight seal...you would know!
So, my recommendation, clean the plug bore and coil pack up well and check it again on a few thousand miles....
« Reply #14 on: 28 December 2006, 15:53:55 »
LOL, I guess its one of those only reconised when its been seem before.  So, Mark, do you suffer from KHMS?
