Author Topic: i am about to experience the joys of omegas .. eml  (Read 7154 times)
tyreburner
  • bedlington - northumberland
  • It werent a mig but boy was it fast!!!!! R.I.P
« on: 28 December 2006, 09:42:51 »
just got maggie, as you know and will be doing a paperclip test shortly, just wondering though any one come across an eml that flashes quite often comes on for between 1+10 secs, doesnt matter if doing 90 or 30 accellerating/braking, straight line/cornering, bumpy/smooth road?
have toed it when light on and DEFINATLY not in limp mode :o (as the i own the road and am overtaking everyone 325 found out  as i pulled out on him and dissappeared into the distance lol)
will check as many connections as i can but any ideas as it's cold and dont wanna have bonnet up longer than needed
read vx omega handbook ( sad i know )and it says that eml coming on and going off again is of no significance????
Cheers in advance
Mick
"well at least I'm lucky I don't have all the power in the world so I can't opps everything else up."
Markjay
  • London
Re: i am about to experience the joys of omegas ..
« Reply #1 on: 28 December 2006, 10:23:49 »
It shouldn't come on that often, this is not normal IMO, may not be a serious problem but check the codes...
What year/model etc?
Alas, no more Omegas....
tyreburner
« Reply #2 on: 28 December 2006, 10:32:46 »
its a 95 elite
« Reply #3 on: 28 December 2006, 10:33:28 »
As MJ says, what year and model? If facelift, can you describe the light - there are 2, one relating to engine and one relating to emissions.
Is the EML actually flashing as if it is intended to flash (as opposed to flickering)? - This is the engine ECU not receiving immobiliser signal.
Of course, booting it around like you do, sure it ain't the traction control light ;)
tyreburner
« Reply #4 on: 28 December 2006, 10:40:30 »
eh? me boot it, no i only did it once to show bmw up as coincidently the eml was on  ;D, and the only other time i booted it yet was to test sports mode when i got her, i intend to treat this car with respect ::) it isnt flickering or flashing, it comes on  and goes off..
thanks in advance
mick
P.s no i know it aint traction light as stated it does it at any speed under any condition.... in fact whenever she wants to?? :(
« Reply #5 on: 28 December 2006, 10:45:14 »
thanks in advance
mick
I was just kidding about the TC light ;)
On a 95 model, one one EML, so just paperclip it and report back.  Do this sooner rather than later - it may be onset of a failing sensor that may let you down big time soon.
As yours is a v6, do paperclip test with engine running so you don't get a false 31.
tyreburner
« Reply #6 on: 28 December 2006, 10:47:30 »
thanks for speedy reply gonna do test now, tina has already cursed it by reminding me of her cr**k sensor going ..... but i am forbidden to say the word( long story but took 3 days to source and get right tools and 20 mins do the job lol)
Mick
« Reply #7 on: 28 December 2006, 10:49:23 »
Mick
I am thinking crank sensor myself. Hence why I said do test straight away (with engine running), and if 19 or 31 come up, down to the dealer you go...
« Reply #8 on: 28 December 2006, 10:50:18 »
Mick
And as Tina will probably remind you, crank sensor is probably the one sensor on the car (on a v6) that doesn't have a limp mode, and that means you break down :(
STMO123
« Reply #9 on: 28 December 2006, 10:51:43 »
Mine did this for a while before knock sensor failed (well, knock sensor lead anyway)
« Reply #10 on: 28 December 2006, 10:53:58 »
If it was knock sensor, it would be on reduced power (ignition would be retarded as engine won't be able to detect if that bank was advanced too far and knocking...)
STMO123
« Reply #11 on: 28 December 2006, 10:56:21 »
Mine didnt lose any power until the EML came on and stayed on, while it was intermittent it was fine. But, then again, might not be knock sensor.
« Reply #12 on: 28 December 2006, 10:58:42 »
Odd, as once the EML is on due to a faulty knock sensor, it has to retard ignition will light is on.  If its a poor connection, the knock sensor may start working, and EML will go out then, and full power returns...
STMO123
« Reply #13 on: 28 December 2006, 11:01:22 »
Mine was the lead shorting/breaking (dont know which).
The EML used to come on if I took a left hand bend sharply ;D
tyreburner
« Reply #14 on: 28 December 2006, 11:16:30 »
hi, done paperclip and it came back with 12 and 98, 12 i beleive is diagniostic and 98 appears to be oxygen sensor? but dont sound too bad, could the o2 sensor be an old code as i have read somewhere on that site ..... (dont know if i dare say the name  :-X) that the lambada has been done? is this the same.......
BUT the earth lead appears to be just a tad loose ( lifts of  with no effort) could this bring light on?
cheers in advance
mick
