Author Topic: Paper Clip Test  (Read 5271 times)
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Paper Clip Test
« on: 31 December 2006, 11:55:32 »
There are frequent references to the above on the site
Please can someone explain what it does, how it's done & how to interpret the results?
Ian
Re: Paper Clip Test
« Reply #1 on: 31 December 2006, 12:01:31 »
Ian
Have a look through here :-
http://www.topbuzz.co.uk/   although I'm not sure whether it covers diseasals.
Pitchfork
Re: Paper Clip Test
« Reply #2 on: 31 December 2006, 12:13:17 »
Your guess was correct - no mention of the 2.5TD (BMW)
Any other suggestions?
Ian
Re: Paper Clip Test
« Reply #3 on: 31 December 2006, 12:16:36 »
Do not believe you can do it on the tractor engine, I think it needs a code reader... :(
Pitchfork
Re: Paper Clip Test
« Reply #4 on: 31 December 2006, 12:24:54 »
Cheers!
That makes 2 issues that cannot be answered, Diagnostics & which engine version I've got
What is it about TDs??
Ian
Re: Paper Clip Test
« Reply #5 on: 31 December 2006, 12:32:04 »
BMW crap ;)
Taxi_Driver
Re: Paper Clip Test
« Reply #6 on: 31 December 2006, 20:26:28 »
BMW crap ;)
Actually i do quite a good job i think......dont get lost too often...and im not made by BMW  ;D
Re: Paper Clip Test
« Reply #7 on: 31 December 2006, 20:57:02 »
BMW crap ;)
LOL...
Omegatoy
  • UK
Re: Paper Clip Test
« Reply #8 on: 31 December 2006, 20:57:58 »
BMW crap ;)
Hmm!!! not going to comment, but its impressed me!!
which is quite something!! not to mention three people who have driven mine and gone out and bought one on the strength of the test drive!!
Omegatoy
Re: Paper Clip Test
« Reply #9 on: 31 December 2006, 21:39:47 »
BMW crap ;)
Omegatoy
Maybe, I should have said "BMW crap, even more detuned in an Omega, but tunable up a a fair bit" ;)
Actually, I like diesels, just not impressed with this one in std form (esp in Omega, but also in Landrover and BMW specs)...
Having reasonable torque (for low revs) and a turbo does make it quite chippable though :y
Re: Paper Clip Test
« Reply #10 on: 31 December 2006, 21:47:29 »
BMW crap ;)
Omegatoy
I have to say i was impressed, was a very smooth engine. For a 12 year old diesel, its very impressive silky smooth. The mods omegatoy made sure make it quick out of the blocks (chipped & fan strapped to the turbo)
Can't comment on the standard version.
Re: Paper Clip Test
« Reply #11 on: 31 December 2006, 21:54:54 »
BMW crap ;)
Omegatoy
The standard is something like 130bhp - less than your 2.2. Lots more torque, but no high rpm power like your 2.2 has...
Couple with the extra weight of the engine (the bmw straight six diesel is very heavy), and in standard form makes it sluggish around town.  Like any diesel though, a fantastic motorway cruiser - at motorway speeds, its right in middle of it power range...
But then, even V6 can be cumbersome around town - lot of metal to get moving...
« Last Edit: 31 December 2006, 21:55:56 by TheBoy »
Pitchfork
Re: Paper Clip Test
« Reply #12 on: 01 January 2007, 12:48:52 »
Well I'm happy enough with it's performance - a very good workhorse hauling around a considerable weight of PA gear & instruments etc. Only wish would be improved economy, not interested in speed or acceleration too much.
Still would apreciated knowing which engine type & therefore which cruise stalk to order though
Also having read several references to the door checks & 'clunks', I've got a clunk. Is there a bush involved in the pivot? If so what part No. do I need to obtain?
Ian
Re: Paper Clip Test
« Reply #13 on: 01 January 2007, 12:54:26 »
Pitchfork, I'm glad the tractor engine suits you well. Due to the torque, it is good at lugging weight around, and for towing. It won't win any races from the lights, but who cares about that ;)
Probably best ordering stalk from dealer, they should know which one it is - I would guess either of the 2 wire ones should work fine.
Absolute first thing to do about door is replace the cheap plastic bushes (few pence each) - guide and part no in Maintenence Guides section here...   ...if that doesn't cure it, then there is a kit to reinforce it...
Re: Paper Clip Test
« Reply #14 on: 01 January 2007, 12:54:46 »
:-/ Oh? I don't know about that!  ;) I had an Astra in tow (literally) the other night and I still managed to keep up as we set off from the lights - I even left one bloke, who was obviously dawdling!  ;D
Instantaneous fuel consumption was just about in double figures though.  :(
