Author Topic: Cruise & dodgy idle speed  (Read 6277 times)
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« on: 27 December 2006, 20:30:54 »
OK my idle speed is still erratic but it now has a twist.  If I slow down in gear to less than 1000 rpm as soon as I slip it into neutral ( it's a manual) the revs bounce back up to 1100/1200 rpm and won't drop until the speedo hits 0. When speedo hits 0 it drops to 7/800 rpm but if I slip it into neutral with the wheels turning it won't drop below 1200 rpm.  It operates smoothly in every gear and does not seem to stick at all.
I've cleaned the breathers, replaced the throttle body gasket after cleaning it and lubing with 3in1 oil.  I've even renewed the little semi clear pipe just in case but it's no different.  I borrowed a working MAF from a 2.2 recently and it made no difference. All the hoses are in good order and I cannot find any splits or leaks. Emissions light is still on.
Q. As the throttle seems to be linked to the speedo could it be some kind of feedback from my cruise upgrade?
Omegatoy
  • UK
Re: Cruise & dodgy idle speed
« Reply #1 on: 27 December 2006, 21:06:38 »
Hmm dont take this as gospel as i know it from gsi carlton 24v!!! however they do the same thing as the idle control valve is controlled by the ecu and gets a feed from the speed sensor, follow that ? now if you slip the car into neutral at any speed above 5mph the ecu tells the icv to hold the revs at approx 1200 to make sure you still have pas and brakes available, when the car finally slows below 5mph the tickover will reduce tonormal, am guessing that the Omega has an even bigger safety margin and wont let the revs drop till it gets a msge from the speed sensor that says zero>>>> make sense to ya?
course i could be totally wrong but thats my take on it mate
Omegatoy
« Reply #2 on: 27 December 2006, 22:09:01 »
Omegatoy
I'll have to try that in mine, never put it in neutral while going along, i picked up a habbit my dad did, going though the gears as you approach a roundabout.
I'll give mine a go...
Chopsdad, you checked the breather pipe (thin one) and throttle body? Could be clogged or partial blockage?? Cleaning that very thin pipe made mine run smoother.
Chopsdad
  • Keep it clean!
« Reply #3 on: 27 December 2006, 22:56:58 »
Omegatoy
I did better than that Tunnie - I bought and fitted a new one today as I thought this may be the source of the air leak.  PS I have to knock it into neutral round town or it keeps the revs at 1200 and feeds in enough fuel to match - hence pushing the car along when I want it to stop (and brakes are much cheaper than gearboxes.)
Thanks Omegatoy - it drops sharply and holds at 1200 so you could well be right.  Maybe my ECU or Speed sensor is picking up the wrong lower end speed - ie 0?
« Reply #4 on: 28 December 2006, 10:56:35 »
Did they update the ECU software at same time? Just wondering if its a new trait of newer software?
Chopsdad
  • Keep it clean!
« Reply #5 on: 28 December 2006, 11:38:09 »
I'm not sure TB - it was all done with a nod and a wink.  Plus it never worked as there was no clutch switch.  I'll ask the Techie but I think he just enabled the cruise function but it's a new place to look.  Thanks
« Reply #6 on: 28 December 2006, 18:16:20 »
When you removed the throttle body did it get a realy good clean including the edges of the throttle disc and sides of the throttle wall?
Were all the vac pieps re-connected including breathers tank purge valve and brake solenoid.....I assume all these are in good nic with no holes etc.
Is the climate/heating etc working all a ok.
Chopsdad
  • Keep it clean!
« Reply #7 on: 28 December 2006, 22:21:29 »
Throttle body was black underneath but now cleaned with Carb Cleaner to as new condition . Breathers were ok with the exception of the metal pipe from the sump all vac pipes reconnected and the small one renewed.  Climate operates normally with no concern. Throttle disc does not close completely - it sits slightly open when at rest.  Fuel consumption way down on normal. 30 mpg at 75 mph on 40 mile M6 trip.  Oil changed today (6m old) & very dark.
« Reply #8 on: 28 December 2006, 22:25:52 »
Errmm thats the main back breather pipe?? Correct me if i am wrong but it should not have that brown kak in there!  :o
Chopsdad
  • Keep it clean!
« Reply #9 on: 28 December 2006, 22:29:19 »
It hasn't anymore - lots of short trips since moving house  :-/ & never been cleaned in 3 years / 40k..
« Last Edit: 29 December 2006, 21:10:27 by Chopsdad »
Chopsdad
  • Keep it clean!
« Reply #10 on: 30 December 2006, 11:14:21 »
I've been to Vx today and the Techie is off till next week. So I'll have to wait to find out what he did - if anything  :(
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #11 on: 30 December 2006, 16:22:14 »
But it could be clogged up inside the cam cover....
I like red cars
Chopsdad
  • Keep it clean!
« Reply #12 on: 30 December 2006, 20:52:25 »
[/quote]
The inside of the filler cap is spotless and no trace of water in the oil I changed this week so I hope not.
« Last Edit: 30 December 2006, 21:34:53 by Auto_Addict »
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #13 on: 30 December 2006, 21:41:55 »
[/quote]
I meant the metal tube (cam cover end) that the rubber hose slides onto, did you make sure that was clear?
I like red cars
Chopsdad
  • Keep it clean!
« Reply #14 on: 30 December 2006, 21:53:29 »
[/quote]
Are you having a giraffe AA?  :o  The pic posted in the thread is the top of the metal pipe with the rubber hose removed before I took it off and cleaned it up - as per the helpful guide you made me  :y
