Author Topic: a happy medium ??  (Read 7001 times)
Re: a happy medium ??
« Reply #15 on: 31 December 2006, 14:34:55 »
right, both drain scuttles clear, no leaks, both rear "bin holds" clear but still having probs. having sunroof on tilt helps a lot so will keep plodding away, ill get there in the end..... cheers for help. :y
Assuming car is not letting in water anywhere, I suspect its just residual dampness in car that you need to remove...  ...driving with as much airflow as possibly is one (slow) way...  ...a proper dehumidifier is the quickest...
STMO123
« Reply #16 on: 31 December 2006, 14:45:42 »
Pollen filter changed?  Blowlamp taken to carpets and upholstery? Driven for six hours with windows and sunroof fully open?
If you're gonna do a job.......... ;D
sir moanalot
  • fens
« Reply #17 on: 31 December 2006, 16:29:14 »
pollen filter changed a month ago, i will have to give it a couple of hours with a elecy heater in it then a good trip (weather permitting) with all the windows etc open, ive gotta solve this problem cos its becoming a major headache.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #18 on: 31 December 2006, 16:57:20 »
I started to have this problem, ran it for a week on ECO, problem disappeared, back on air con again.
I like red cars
STMO123
« Reply #19 on: 31 December 2006, 17:42:25 »
I NEVER drive on anything other than ECO in the winter. I know that people say turn the air con on once a week to keep it lubed but I do that when sitting in my drive, and not for long. I'm pretty sure I read in the manual it says something like "only use air con when warm outside".
Will go and have a look.
EDIT: No, must have dreamt it. But, dont know if air con is different from CC.
« Last Edit: 31 December 2006, 18:15:57 by STMO123 »
paolo
  • Holmfirth, West Yorkshire
« Reply #20 on: 31 December 2006, 18:09:37 »
what is the difference between climate control and air conditioning?
which is best?
what tips and tricks are recommened for longivety of the afore mentioned....any hints like don't have it on full blast while the car is stationery or not warmed up etc
how badly does it affect fuel consumption?
Cars 7 sports...I love old cars.
« Reply #21 on: 31 December 2006, 18:16:01 »
which is best?
Climate is the digital type, set the temp, and it sorts itself out. All climate systems have A/C.
A/C is generally meant to be the traditional heater systems.
All facelifts have climate, as do prefacelift CDX and Elites from around 1996
STMO123
« Reply #22 on: 31 December 2006, 18:33:56 »
You've bought a 3.0 omega Paul. Forget about fuel consumption ;D
« Reply #23 on: 31 December 2006, 19:38:53 »
about 1mpg in my tests...
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #24 on: 31 December 2006, 19:39:55 »
i notice very little difference fuel consumption when the A/C is on or Eco, at the best it equates to a mile or so per gallon.
mines a 2.5 but i cant see the loss on a 3.0 being that great..
familyman
  • Sittingbourne, Kent
« Reply #25 on: 02 January 2007, 14:10:29 »
Running with a/c swictched on during demisting should help because a/c system naturally dehumidifies the air.
Pretty much all modern cars with a/c automatically cut the a/c in when switched to demist anyway.
Try initailly not wanging the temp over to hot straight away but try cool or midway first and see if this helps.
Climate control does what it says on the tin controls climate temp and humidity in car automatically.
 a/c will just cool the air with some control over humidity controlled manually by the temp control :y
You came in that, your braver than i thought
