Author Topic: Cam sensor removal stuck!  (Read 2029 times)
« on: 03 January 2007, 16:03:11 »
Removed the 10mm nut on the cambelt cover, so i can lift off the mass of looms and wires that go across the front, although not very far.
Still can't pull the cambelt cover back very far at all, can barley see the top of the belt and a few teeth on the cogs!
Where abouts is the nut to release the sensor, nothing in Hayes about it i assume its something only on the 2.2's not 2.0's?
mar892ree
  • Northampton
  • if it dont undo, hit it wiv an hammer
Re: Cam sensor removal stuck!
« Reply #1 on: 03 January 2007, 16:12:58 »
It should unplug Tunnie, leave cam sensor in place, no need to remove !
« Reply #2 on: 03 January 2007, 16:20:59 »
I need to remove it, its been giving a tech2 error since the summer!  :-[
I have unplugged the loom at the top, remove all the screws i can find (E11) to the cambelt cover, still can only pull it back a cm's at best... no ware near the access room i need. Can only pull it back at the top, still seams fasted in the middle someware but can't find any screws holding it in  :-/
Matchless
  • Nottingham
    • A white van
« Reply #3 on: 03 January 2007, 16:22:46 »
have you removed the pillars that the cable tray fastens to?
« Reply #4 on: 03 January 2007, 16:25:32 »
errr  ::)
The cable tray that goes across the front of the engine? with the big loom cables going though it? - I removed the nut underneath that which alloys the tray to slide upwards, but it does not go enough the loom cables stop it going very far
Taxi_Driver
« Reply #5 on: 03 January 2007, 16:30:03 »
Take the nut and washer off underneather the tray......pop the cover of the top of the tray....remove the tray leaving the cables behind...pull the cables upwards so it allows the cambelt cover to come back as far as the aux belt  :y
Matchless
  • Nottingham
    • A white van
« Reply #6 on: 03 January 2007, 16:30:24 »
Is the cable tray fastened to the cam cover by two nuts?
Remove the nuts and release the cable tray.
The two nuts screwed onto a stud sticking out of a 10mm hex pillar....undo the pillars and cover should come off...if you found all the other bolts.
« Reply #7 on: 03 January 2007, 16:31:00 »
right, i'll give that a go. Cheers  :y
Page created in 0.009 seconds with 20 queries.
