Author Topic: 2.5TD water pump  (Read 1632 times)
rhinodriver
  • Leominster, Herefordshire
2.5TD water pump
« on: 30 November 2006, 22:12:47 »
can anybody tell me how to change the water pump on a V reg 2.5TD PLEASE !!!!!!!!!!!!!
Re: 2.5TD water pump
« Reply #1 on: 01 December 2006, 08:52:24 »
Sorry, never had a TD, but one of the diesel bods should be along shortly...
dane
  • stafford
« Reply #2 on: 03 January 2007, 17:24:00 »
not too big a job. radiator off , fan off. then pump is just three bolts. pump draws out. new pump has o rings fitted, just push new unit in and re tighten.
only difficulty is if you have auto box which is also connected to radiator. carefully undo pipes and fold up out of way. when lifting out rad be carefull not to lose transmission fluid and you should be able to replace without having to top up autobox.
