Author Topic: N/S idler arm  (Read 2865 times)
old cruiser
  • Slough
N/S idler arm
« on: 04 January 2007, 14:59:40 »
Does anyone know the correct torque settings for the idler I know the setting for the one that connects to the centre tie rod assembly which is 60Nm, but need to know setting of the other end where the heat shield connects to.
cheers Pete
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: N/S idler arm
« Reply #1 on: 05 January 2007, 07:10:39 »
BTT
I like red cars
nixoro
  • Hitchin, Herts
Re: N/S idler arm
« Reply #2 on: 05 January 2007, 12:02:41 »
cheers Pete
Anyone on here with a haynes to hand :question as I have no Idea sorry :-[
« Last Edit: 05 January 2007, 12:03:36 by nixoro »
Re: N/S idler arm
« Reply #3 on: 05 January 2007, 12:07:09 »
From memory, its the same again,60Nm....will check later.
old cruiser
  • Slough
Re: N/S idler arm
« Reply #4 on: 05 January 2007, 15:49:28 »
Ok thanks Mark appreciate that if you could.
Would appear that vauxhall state (in the unmentionable!) that the torque setting is 118 lbf ft (160Nm) which to me seems ridiculously tight (maybe this is for the Drop arm on driver's side perhaps) would probably end up stripping the thread, so for the moment I have torqued to 44 lbf ft (60Nm).
Cheers Pete
old cruiser
  • Slough
Re: N/S idler arm
« Reply #5 on: 06 January 2007, 11:23:32 »
Mark did you have anymore joy on that steering idler arm torque setting?
cheers Pete
Re: N/S idler arm
« Reply #6 on: 06 January 2007, 12:10:37 »
As I suspected, its 60Nm
old cruiser
  • Slough
Re: N/S idler arm
« Reply #7 on: 06 January 2007, 12:47:54 »
ok thanks for that Mark.
Cheers pete
