Author Topic: What could be the problem/cause....  (Read 2220 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: What could be the problem/cause....
« Reply #1 on: 07 January 2007, 10:46:19 »
MOT?
I like red cars
« Reply #2 on: 07 January 2007, 10:50:21 »
It's got 8 months MOT and 3 months Tax, might be a bargain if it's an easy fix. Just looking for ideas on what the problem is...
If the box is shagged then I'll leave well alone, but if it's a known issue I can cure, I'll watch it ;D
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #3 on: 07 January 2007, 11:54:44 »
£100 quid - if you've got the room get it and then worry about it later. :y
« Reply #4 on: 07 January 2007, 11:56:19 »
Agreed matey, but I think it will go beyond that money with 2 days to go.....
RobC_NE
  • North East
  • IMI and VSIB Qualified Auto Electrician
« Reply #5 on: 07 January 2007, 20:24:55 »
could be the box is screwed, or maybe just the slector rod is damaged (or cheaper, loose) when mine was loose it kepd dropping out of drive...
keep an eye on it, know i will lol  ;D
rob
Saxo, corsa, clit drivers. Before starting on a journey, attach a lit sparkler to the antenna of your car. you drive the thigs like dodgems. for the love of god MAKE IT LOOK THE PART!
« Reply #6 on: 07 January 2007, 21:03:25 »
That does sound more like a box fault....   ...may get away with fresh fluid??
Matchless
  • Nottingham
    • A white van
« Reply #7 on: 07 January 2007, 22:32:16 »
Its high mileage.
Dont get dazzled by a low price, assume it needs another box and I would also budget for rear shocks, front struts and an a/c condensor plus the usual 'service' items such as cam belt and tyres. Work out the likely costs and set yourself a limit.
No...Im not bidding on it and trying to put anyone off, my last estate had 150k on it when I moved it on so I know what can be needed on higher mileage barges.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #8 on: 07 January 2007, 22:55:56 »
Its high mileage.
Sound advice :y
I like red cars
