Will this work with my 1995 V6 Meega?
Started by JamesV6CDX, 09 January 2007, 15:29:56
QuoteInteresting stuff, my thinking was that eBay box would work because your tech2 worked on my '95 Elite (although with limited capabilities)
Whist on the subject and sorry to hi-jack, I take it there is no way it can read a Senator? - I assume that needs a Tech1 connection, is it backwards compatible?
Read on the systems on you Elite except the AWTS (earlier type, not fitted after 1995) and seats (not sure if it was due to wrong ECU, or because of the fault with the seats (no power to ecu?)).  The cheapo one may not be quite so successful.
Tech2 won't work on Senator, Tech1 required. Tech1 can generally be picked up for a few hundred £...
Thats more than the car! Think i'll use a paper clip  ;) :D
Quote......
and you'll be able to read the gearbox, alarm, digi dash (obviously if fitted) ride control suspension.
Quote......
cool cheers for that  :y
