Author Topic: newbie problems  (Read 6386 times)
zywiec
  • Cambridge
newbie problems
« on: 09 January 2007, 23:06:57 »
Hi just got a 2000 2.5 v6 omega cdx
got a few probs i hope you can help me out with, im not to bad with a spanner so hoping for home fixes.
1. passenger window and wing mirror dosnt work/adjust (hoping its just a fuse but havnt had i chance to check them yet will do soon as its light in morning)
2. windscreen washer dosnt work the motor is working and the headlight jets work fine so hoping theres a blockage somewhere.
3. crusie control isnt turning on (i have no idea where to start on this)
4. drivers heated seat dosent work but passenger one is fine if its the heating element on the seat how much am i looking at?
thanks for taking the time to read any imput would be greatly appreciated.
greg
Re: newbie problems
« Reply #1 on: 09 January 2007, 23:16:18 »
Hi Greg,
Welcome to the site  :y
We need a little more information to help you out there, is your car a facelift Omega or pre-facelift?
Easiest way to check this is you electric windows, are the buttons for the windows:
on the centre column (gear stick area) =  pre-facelift
on the door = facelift
2000 was just on the changer over.... so thats why we need to know as there were some major changes in the design  :y
Bo Bo
  • Coventry
Re: newbie problems
« Reply #2 on: 09 January 2007, 23:16:49 »
There's a "how to" for the washer jets here.
zywiec
  • Cambridge
Re: newbie problems
« Reply #3 on: 09 January 2007, 23:21:31 »
Hi Greg,
on the door so face lift
@ BO BO thanks alot ill have a look in the morning.
Re: newbie problems
« Reply #4 on: 10 January 2007, 19:07:25 »
greg
1) Switch can be a prob, check switch with meter
2) Blocked gauze, check link Bo Bo sent
3) As this car is new to you, check you have actuator and cable under bonnet. Check stalk is correct on. Check correct brake and clutch switch fitted
4) If its leather, can be a PITA. Cloth apparently easier. Before doing, check wiring to seat, but be careful with side airbags and seltbelt pretensioner!!
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
Re: newbie problems
« Reply #5 on: 10 January 2007, 20:11:23 »
greg
Facelift - DBW?
Re: newbie problems
« Reply #6 on: 10 January 2007, 20:28:55 »
greg
Facelift - DBW?
Sig says 2.5, so not DBW...
Chopsdad
  • Keep it clean!
Re: newbie problems
« Reply #7 on: 10 January 2007, 20:30:41 »
greg
Facelift - DBW?
I don't know much - but I know a little more now  :-[ :y
zywiec
  • Cambridge
Re: newbie problems
« Reply #8 on: 10 January 2007, 22:18:19 »
greg
Facelift - DBW?
thanks for the help
1) will check the switch but it dosnt work on eith drivers side or passenger would this effect the whole circuit.
2)yeap gauze blocked fixed working fine now
3)where would i find the actuator (what dose it look like) the stalk appers on correctly as the indicators and the flashers work ok
4)not leather what is a PITA.
Re: newbie problems
« Reply #9 on: 10 January 2007, 22:23:27 »
PITA = Pain In The Arse  :y
Re: newbie problems
« Reply #10 on: 10 January 2007, 22:23:36 »
thanks for the help
1) I would need to check the diags. Yes, failed switch could stop it working
2) :y
3) Are there 2 throttle cables going to throttle body - one goes through bulkhead to pedal, other goes to actuator mounted on driver side inner wing...
4) PITA = Pain In The Ass
zywiec
  • Cambridge
Re: newbie problems
« Reply #11 on: 10 January 2007, 22:29:54 »
lol like every car ive owned
zywiec
  • Cambridge
Re: newbie problems
« Reply #12 on: 10 January 2007, 22:34:20 »
can any one recomend a manual as hanes dont do one that i can find?
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
Re: newbie problems
« Reply #13 on: 10 January 2007, 22:43:11 »
they do one for the pre-facelift, the engine is the same on the facelift models, most of the mechanicals are the same anyway ...
Re: newbie problems
« Reply #14 on: 10 January 2007, 22:50:56 »
Hayes say the differences in the facelift did not warrent a new book.
However since you have a 2.5 that is much the case, your engine is the same as pre-facelift.
