Author Topic: ifomega cut out  (Read 5301 times)
dragon33
  • swansea
ifomega cut out
« on: 13 January 2007, 15:04:50 »
hi to all ,i wonder if anyone can help me.just spent 2 hours in the wind and rain checking my plugs ,put everything back together ,car staerted fine ,i went under the bonnet to rev the engine there to check my exhhaust manifold,then the car just cut out and now will not start,ive got an omega 2.5v6 m reg
regards stuart
kjon51
  • Oldsville - East Sussex
Re: ifomega cut out
« Reply #1 on: 13 January 2007, 15:18:50 »
Maybe the wind & rain has got in somewhere it shouldn't have?
As someone elses signature says, have you checked the fuses?
Assuming it's turning over & not firing - petrol? OR - Have you moved some wires around/loosened a connector?
dragon33
  • swansea
Re: ifomega cut out
« Reply #2 on: 13 January 2007, 15:31:58 »
its just strange as it ran for about 40 seconds then just stopped,so it fired up ok,it seems like a fuel problem ,but got fuel ,any ideas on how to check fuel is pumping,is itpossible immobiliser,the only wires disconnected were in the loom above the spark plugs on passenger side of engine
Re: ifomega cut out
« Reply #3 on: 13 January 2007, 18:35:44 »
Do a paperclip test...
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
Re: ifomega cut out
« Reply #4 on: 13 January 2007, 20:53:46 »
Fuse for fuel is 20a - this guide will show you its location http://www.omegaowners.com/forum/YaBB.pl?num=1161602008 - , but takes a lot to blow, but car would just die as you've described so it's possible.  Worth a try - 20 sec job.  :y
« Last Edit: 13 January 2007, 20:54:34 by Chopsdad »
dragon33
  • swansea
Re: ifomega cut out
« Reply #5 on: 13 January 2007, 21:26:11 »
checked all fuses everything ok .any advice on the electrics i disconnected in above the plugs on passenger side of engine 3 plugs all together ,1 is connected to a bosch cylindrical unit dont know what that is though it is mounted in a rubber holder.
rpont
  • Tadcaster
Re: ifomega cut out
« Reply #6 on: 13 January 2007, 21:38:53 »
That's the idle control valve (IVC). Check that the plug is fully in because if not the engine will die and not start unless you give it a tiny bit on the accelerator.
dragon33
  • swansea
Re: ifomega cut out
« Reply #7 on: 13 January 2007, 21:42:13 »
thanks buddy will check it out tomorrow
dragon33
  • swansea
Re: ifomega cut out
« Reply #8 on: 13 January 2007, 23:11:57 »
cleaned idle conrol valve still the same problem.checked wires in loom and now she is firing but still wont fire up,think i got a connection problem to icv but what symptoms would this cause any ideas???????
Re: ifomega cut out
« Reply #9 on: 14 January 2007, 10:57:29 »
Did you do the paperclip test, if so what were the results?
dragon33
  • swansea
Re: ifomega cut out
« Reply #10 on: 14 January 2007, 18:34:35 »
havent done paperclip test yet,got up this morning ,checked all wires i disturbed for open circuit all ok,then car started fine ,so i still dont know why,only had this car for two weeks and now i got  an exhaust noise ,i think exhaust pipes from engine are blowing any ideas on cost
Matchless
  • Nottingham
    • A white van
Re: ifomega cut out
« Reply #11 on: 14 January 2007, 21:32:49 »
Sounds like you have a dodgy connection waiting for the next dark wet cold night.
Do a paper clip check and post the results, there should be fault codes stored to point you to which device or sensor was at fault.
Where is the exhaust noise coming from?
If its in the engine bay its most likely to be exhaust manifold gaskets or possibly a warped or cracked manifold, otherwise work back along the system. The mid boxes can sound noisy if the internal baffles have rotted out, there wont be any external blow but may rattle if thumped by hand.
dragon33
  • swansea
Re: ifomega cut out
« Reply #12 on: 14 January 2007, 21:43:01 »
definitely engine bay just sounds rough
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
Re: ifomega cut out
« Reply #13 on: 14 January 2007, 21:45:07 »
exhaust noise form engine bay....
might it be EGR related??
it's precisely what I've just had fixed.....      all of a sudden the engine ran lumpy and threatened to stall at tick over.... and the exhaust sounded bad at the front....
turned out the EGR had "failed dramatically" .... replaced, and all sorted.....
dragon33
  • swansea
Re: ifomega cut out
« Reply #14 on: 14 January 2007, 23:05:22 »
that sounds like it ,how much did that dent your funds?
