Author Topic: steering box faulty ??  (Read 2500 times)
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« on: 12 January 2007, 10:56:39 »
2.5td ('94) turns to the right "quicker than a go-kart" to the point that if I turned in any more the rear end seems to be on the verge of breaking away as if I had hit the loud pedal to hard.
The steering feels over responsive and "un-dampened"  and does not return to central (straight ahead) position when turning to the right but is normal to the left.
Any one else suspect this to be a faulty steering box ?
Steering idler changed yesterday. Wishbones, wheel bearings, drop-links, rear main bushes and the engine cradle all done in the last 6 months.
Mileage is 217,000
Re: steering box faulty ??
« Reply #1 on: 12 January 2007, 12:05:34 »
With the engine running and not moving, is there:
a) Little or no assist until the engine is revved?
b) any free play in the steering?
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #2 on: 12 January 2007, 13:20:55 »
Steering is not heavy as in "no power steering" even at tick over.
Steering idler was done yesterday, so there's no freeplay. Not that there was much b4 changing the idler.
Matchless
  • Nottingham
    • A white van
« Reply #3 on: 12 January 2007, 14:32:47 »
I would guess steering box but check the front strut top bearing has not seized on one side, if it has then can cause a spring to 'wind up' so that it is trying to twist the strut round on that side.
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #4 on: 12 January 2007, 17:04:42 »
O.K, I'll check the top bearings. I had a "clonking" sound but that has gone after I re-tightened the top mounts, but I haven't actually checked the bearings.
Cheers me deers
« Reply #5 on: 12 January 2007, 18:43:40 »
Could there be a geometry issue that needs sorting?
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #6 on: 13 January 2007, 11:31:34 »
As for the geometric side of things, I've had the 4 wheel alignment and the camber checked (car is lowered with camber kit fitted).
As a short term diagnostic, I'll take off the top mount nuts, push the damper rod down a little and see if things improve with a dose of WD40.  If that sorts it, I'll get new top mount bearings and do it properly.
« Reply #7 on: 13 January 2007, 11:53:57 »
I would still consider a full geometry check, even if the bearing fixes the problem.  4 wheel alignments are a bit of a waste of money imho.
Let us know how you get on with the bearing...
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #8 on: 15 January 2007, 14:21:23 »
Tried a dose of Lithium spray grease via the top mount holes but no. change...except that the "clonking" over pot holes that was there b4 I tightened things up last week has now returned.
Somethings not right there, even if the steering box has gone.
I reckon it's worth doing the top mount bearings.
Any one got a diagram showing these bearings and a brief "how to", other than legs off completely ?
...and are they available as a pattern part or is it a main dealer jobbie ?
