Author Topic: errr...   sudden engine shut down.....    (Read 5143 times)
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« on: 17 January 2007, 09:43:18 »
Hi all....
I had a nasty surprise this morning while on the school run......  all of a sudden, with no warning, no rough running, no nothing...  the engine cut out on my 3.0 Elite...  not quite at idle, but low speed with minimal throttle....
I switched off all ancilliary things like heater, lights, stereo, and turned the key... and bingo... it restarted just fine....
...odd....  i thought.....
then on my way home, sat in traffic, idling... it did it again......   it just stopped running.... no other symptoms...   and only the usual complement of warnings lights that you'd expect to see when the ignition is on, but the engine is not running....
and likewise, it started straight away again....   no problem, no hesitation, no nasty noises.....
Somewhere or other, I have one of those gadgets that makes the paperclip test a little easier (effectively a switch wired to short across the right connections, and fitted with the plug for the data socket)..
So i'll dig it out and see if there are any fault codes with and without the engine running....  and post them later...
meanwhile, can anyone think of a cause for this....  ?????
The only ones that immediately spring to mind for me is perhaps the crank sensor starting to go faulty....????  or it's wiring perhaps being damaged or connector loose....
anyone got any other ideas I should also investigate....   I guess I'm just lucky this didn't happen at speed on the ring road....
I cannot repeat the fault "at will" which makes me nervous... i hate not being able to actually predictably demonstrate a fault whilst in the process of identifying it....  it leaves me open to huge bills... and I'm skint after just paying £500 or so for new rear wheel bearing and EGR valve replacements
any suggestions gratefully accepted.......
Max
Admin
Re: errr...   sudden engine shut down.....
« Reply #1 on: 17 January 2007, 10:51:41 »
That will be your crank sensor then. :)
Start it up (assuming it will) and expect to see a code 19.
Easy job to replace, just make sure you get the correct sensor.
The Administrator.
Re: errr...   sudden engine shut down..... &n
« Reply #2 on: 17 January 2007, 12:13:25 »
yep classic crank sensor symptoms
MaxV6
  • Oxford UK
« Reply #3 on: 17 January 2007, 12:28:48 »
Thunk.
the sound of a nail being hit squarely on the noggin....  code 19 alright....
i must have been plumb lucky to get it home this morning as the bastardo won't fire up at all now....
hey ho....  back to the garage it goes......  thank god they're only right over the road from me....
is £49.50 an hour a decent rate these days???
(+Vat)
and can anyone confirm that 90540743 is the right part number for a 3.0 V6 engine no 8297696  ??
ta muchly chaps.....
« Reply #4 on: 17 January 2007, 12:49:30 »
£50 + vat an hour? humm thats high tbh, i know Vx dealers which charge less!
I could see myself selling my services here  ::) ;D
MaxV6
  • Oxford UK
« Reply #5 on: 17 January 2007, 13:10:47 »
where????
nixoro
  • Hitchin, Herts
« Reply #6 on: 17 January 2007, 13:24:30 »
Why not save on the labour costs and do the job yourself atleast then you know the job will be done properly, others on here have done the job so there should be plenty on here who would be able to advise if needed.
Buying the part well, might be worth checking www.autovaux.co.uk or possibly contacting someone with TC atleast then you will end up with a genuine GM part.
With Autovaux though its best to ring them as they do get busy.
Just my tuppence worth :y
*editted*
My apologies just read your newbie thread kinda rules my idea out :-[
« Last Edit: 17 January 2007, 13:27:55 by nixoro »
Admin
« Reply #7 on: 17 January 2007, 13:38:59 »
Changing the crank sensor is one of the easier jobs on the Omega.
I have got it down to 12 minutes now! ;)
The socket end of the sensor sits at the back of the engine behind the rear multiram.
The other end is next to the oil filter held on by a T8 (I think) torx bolt.
Just realised, we don't have a how2 guide for it on here!  :o
Anyway. If you are getting a garage to do it give them this important piece of information.
DO NOT try and re-route the same way as the original!
This will take considerable time and runs way too close to the exhaust (cooks the cable).
Instead, route the sensor wire down the side, attaching to the pipework on the passenger side of the engine bay.
This keeps the cable clear of the exhaust and is also much quicker to complete the job (ie garage should take no more than 30 mins!)
The Administrator.
MaxV6
  • Oxford UK
« Reply #8 on: 17 January 2007, 14:24:45 »
I can see myself being quite eager to pay someone hereabouts a more reasonable (in relative terms ;) ) rate to do some of these jobs......  in the near future  I'm about to need to do Cam belt and water pump on BOTH V6's   .......  Secondary air and front brakes  on the Sintra need sorting.... and both gearboxes could use a complete fluid changes and new filters.....   ... the list goes on....   and I'm in no position to do it myself....
 it's not technical skills that I'm short on... (I'm an Engineering and Physics graduate....... ) it's physical ability....  I broke my neck and damaged my lower back in 89 (courtesy of another driver running some red lights ) ... at the time, I made a pretty good recovery, but it's come back to haunt me... affecting the use of my hands for strength and fine motor skills... and ability to bend over etc..   so much so that I'm now technically supposed to be registered as disabled.....  generally I can get along for most things..., so don't feel the need to go the whole Orange badge route... besides... that's kind of like admitting total defeat.... ... but there are times... like now... when It's a right royal pain in the arse...
Max
« Reply #9 on: 17 January 2007, 16:32:27 »
Don't you mean too close to the hot oil pipes ;)
nixoro
  • Hitchin, Herts
« Reply #10 on: 17 January 2007, 16:44:43 »
Its a shame there isn't anyone near you that could perhaps lend a hand.
MaxV6
  • Oxford UK
« Reply #11 on: 17 January 2007, 17:27:47 »
yeah it would be nice,  or better yet....   a gang of Omega Fixing Pixies that creep around at night repairing people's Omega's while the owners are asleep.........
:D
more seriously....  I wouldn't expect anyone to do so out of altruism... although i'm fully aware that many members here are actually that nice "for real" .....  but it's a bit much to expect  members of any social group to do such things "on request", even if  one has "history" within that group and existing friendships and stuff......
what i mean is it's one thing to do so for a mate... no matter how nebulous the relationship...   and quite another for an almost total stranger....
(although weirder stuff happens at sea....  )
ohhh   bloody hell it's not coming out the way it sounded in my head....
but more bluntly....   I don't expect freebies.    not  for any reason.......
sure it's nice when it happens and you can't say no....  rather humbling actually.....
but one should never EXPECT anything of the sort.
if you see what i mean....
nixoro
  • Hitchin, Herts
« Reply #12 on: 17 January 2007, 17:39:47 »
I see what you mean :)
« Reply #13 on: 17 January 2007, 18:13:25 »
I'm not hugely far from Oxford.  I am just a little tied up for next couple of days playing Head Gaskets.  Once thats done, more than willing to help keep cash in your pocket and away from dealer...
« Reply #14 on: 17 January 2007, 21:10:30 »
i would be more than happy to help, unfortunately cambelts is something i have never done. Getting better all the time though can help out on:
DIS Replacement,
Coolant & Oil changes
Brake Pads, sensors & Disc's replaced
ICV Plugs ect...
