Author Topic: EML light on  (Read 2018 times)
Jim Bob2
  • Essex
EML light on
« on: 19 January 2007, 21:46:26 »
What does a continuously lit EML light denote ?
Re: EML light on
« Reply #1 on: 19 January 2007, 21:47:18 »
The ecu ain't happy with something.
Seeing as you have a 2.5, do a paperclip test to find out what...
Jim Bob2
  • Essex
Re: EML light on
« Reply #2 on: 19 January 2007, 21:50:46 »
Year I'll try that tommorrow, thanks.
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
Re: EML light on
« Reply #3 on: 19 January 2007, 21:51:32 »
Drive nice, don't over run the engine, use more fuel and get it fixed.  ;D
Jim Bob2
  • Essex
Re: EML light on
« Reply #4 on: 19 January 2007, 21:57:59 »
Don't over run the engine......Yes maybe it does'nt like being bounced off the rev limiter every gear change.......??
Chopsdad
  • Keep it clean!
Re: EML light on
« Reply #5 on: 19 January 2007, 22:11:18 »
Does you EML have a spanner sticking out of a car or an image of an engine block?
Jim Bob2
  • Essex
Re: EML light on
« Reply #6 on: 19 January 2007, 22:14:15 »
It has the engine block image.
Re: EML light on
« Reply #7 on: 19 January 2007, 22:17:50 »
Its not DBW engine, so thats the only engine management light, unlike DBW ones which have 2...
Chopsdad
  • Keep it clean!
Re: EML light on
« Reply #8 on: 19 January 2007, 22:22:46 »
That's your Emissions light - if the other one comes on it will put your car into limp home mode, reset your timing and make it as fast as a slug.
The emissions light means that the exhaust emissions are too high.  This may be caused by many things but the first thing to check is that all your hoses are tight, with no splits especially around the bellows on the big pipe from the air box.  Next IMO would be to clean the breathers out.  It may be a faulty Lambda (O2) sensor or MAF sensor amongst others.
If the pipes are ok do a paperclip test and post the results - we can then identify the fault code and help fix it.
If it flashes on and off it means you may be killing your cat - and they're expensive to replace.
For what it's worth mine's been on for 6 months and is the reason I came here  - but I got rid of it this week.  ;) :y
Edit - Oh 'dangle berries' didn't know you only had 1 light  :-[
« Last Edit: 19 January 2007, 22:23:33 by Chopsdad »
