Author Topic: Loose HID Bulb  (Read 1935 times)
johndm1957
  • Bedford
Loose HID Bulb
« on: 19 January 2007, 18:57:49 »
If I wiggle the HID power lead, the beam moves around....do I need to strip light unit out or can I get my fingers in there to remove or check the bulb is seated correctly? (I will pull the fuse before I stick my pinkys in).. ;D
cheers
Tony H
  • liverpool
  • Black Elites are luurvley
Re: Loose HID Bulb
« Reply #1 on: 19 January 2007, 19:08:49 »
Wise move re the fuse or you could end up with a hair style like Ken Dodd :o
johndm1957
  • Bedford
Re: Loose HID Bulb
« Reply #2 on: 19 January 2007, 19:48:34 »
So does the bulb actually point to the side of the car, and just release by turning anticlockwise?
Taxi_Driver
Re: Loose HID Bulb
« Reply #3 on: 19 January 2007, 21:05:48 »
Sorry i dont know  :(
Mine runs on candle power  ::)
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
Re: Loose HID Bulb
« Reply #4 on: 19 January 2007, 21:45:00 »
Sorry John no use here either - but nice planes btw - I have a soft spot for the Flying Fortress, used to have one attached to the ceiling with cotton and a drawing pin.  ;)
johndm1957
  • Bedford
Re: Loose HID Bulb
« Reply #5 on: 20 January 2007, 14:54:46 »
Well I can't get my fingers in there to push/twist it in with the ballast thingy in the way. Guess the airbox needs to come off to get to the torx screws holding the black plastic cover, seat lamp, then re-attach cover??
Glad you like the aircraft pix....theres 1000 of them on there if you get bored.... ;D
