Author Topic: Tech2  (Read 5329 times)
drilla
  • midlands
  • I,ll sleep when i'm dead
Tech2
« on: 20 January 2007, 17:31:23 »
 >:( Does anyone know if the cheapo tech2 jobbie will reset the immobilliser fault code on a 96 omega?
Re: Tech2
« Reply #1 on: 20 January 2007, 17:35:48 »
What is the fault with the immobiliser?
drilla
  • midlands
Re: Tech2
« Reply #2 on: 20 January 2007, 17:40:36 »
Hi ya buds, As mentioned before about the meega not starting and the ignition lite staying on after removing the key, I have now brought a new alternator (gonna fit tomorrow) which was giving a high voltage reading which made the immobiliser throw a wobbler
Re: Tech2
« Reply #3 on: 20 January 2007, 17:46:28 »
Shouldn't stop immobiliser working properly, unless its damaged it....
Markjay
  • London
Re: Tech2
« Reply #4 on: 20 January 2007, 17:48:28 »
TheBoy knows all about these things, all I can add is that my Cheapo Tech2 doesn't even communicate with the immobiliser... it's a bit of hit-and-miss with these devices.
Alas, no more Omegas....
drilla
  • midlands
Re: Tech2
« Reply #5 on: 20 January 2007, 17:54:37 »
 :( The fob still works as it still unlocks the car (when the battery is connected) and it will turn over but any ideas why it wont start?
Re: Tech2
« Reply #6 on: 20 January 2007, 17:56:50 »
Does the engine management light flash?
drilla
  • midlands
Re: Tech2
« Reply #7 on: 20 January 2007, 18:02:37 »
yes it does, but havent been able to count the flahes yet
Re: Tech2
« Reply #8 on: 20 January 2007, 18:05:34 »
I meant does the EML flash when attempting to start car, not as part of paperclip test...
drilla
  • midlands
Re: Tech2
« Reply #9 on: 20 January 2007, 18:06:36 »
yes
Re: Tech2
« Reply #10 on: 20 January 2007, 18:08:59 »
Right, so that is the immobiliser telling the engine ecu not to start.
Is the transponder chip still in the key?
drilla
  • midlands
Re: Tech2
« Reply #11 on: 20 January 2007, 18:30:32 »
yes the transponder chip is still in the key
Re: Tech2
« Reply #12 on: 20 January 2007, 18:33:45 »
Have you another key? If so, does that work?
drilla
  • midlands
Re: Tech2
« Reply #13 on: 20 January 2007, 18:37:36 »
no, never had another key
Re: Tech2
« Reply #14 on: 20 January 2007, 18:46:21 »
Your symptoms are showing that the immobiliser isn't able to read a valid transponder chip.
So, either:
  • No transponder in key, or transponder is faulty.
  • The pickup coil isn't working, or wiring problem.
  • The transponder isn't programmed in immobiliser.
  • Wiring problem with immobiliser.
  • Faulty in immobiliser or engine ECU.
I would say, assuming nothing changed since it was working, attempt to get transponder reprogrammed to immobiliser.
But to answer your original question, its unlikely a cheapo tech2 lead would help.
« Last Edit: 20 January 2007, 18:46:58 by TheBoy »
