Pages: [1] 2 3  All   Go Down
Author Topic: Engine management light  (Read 7051 times)
lachleaves
  • Anglesey
  • As fruity as the car itself
« on: 14 January 2007, 11:38:38 »
On my '97 2.5 V6 auto...
Engine management light came on.  Made it to work - no problems.
Started back from work (light still on, again no problems).  She drove all the way home (approx. 25 miles) without hiccup.
Any ideas what it could be?  Whatever it is that's causing the fault, it doesn't seem to be that serious as it's not impeding on the performance of the car at all.
Just get vauxhall to do a diagnostics??
Thanks,
Lachleaves.
Ken T
  • Stockport
Re: Engine management light
« Reply #1 on: 14 January 2007, 12:24:23 »
Try and read out the fault codes yourself. This involves bridging a couple of terminals in the diagnostic connector in the fuse box (if its a 16 pin connector then its terminals 5 and 6), turning on the ignition, and reading out the number of flashes on the SD lamp. If you search for  'omega fault codes'  this should give you enough info to do this. The codes should point you as to what is complaining. No need to pay VX lots of dosh at this stage!. :)
Erthe
  • Berwickshire, Scotland
« Reply #2 on: 14 January 2007, 12:55:34 »
There's a good post on the "paperclip" test found within the forum
http://www.omegaowners.com/forum/YaBB.pl?num=1152601768
If i can manage it...anyone can  :)
(btw...I think it is pins 4 and 6...but would have to re read it)
« Reply #3 on: 14 January 2007, 16:09:32 »
#(btw...I think it is pins 4 and 6...but would have to re read it)
Pins 4 and 6 or pins 5 and 6. Makes no difference ;)
« Reply #4 on: 14 January 2007, 16:10:20 »
Thanks,
Lachleaves.
Is it a 2.5 or 2.6? If 2.5, do paperclip test. If 2.6 you cannot do paperclip test, but can you describe what lights look like...
« Last Edit: 14 January 2007, 16:11:09 by TheBoy »
lachleaves
  • Anglesey
« Reply #5 on: 14 January 2007, 18:36:14 »
Thanks everybody.
I'll give it a go.  (it's a 2.5 by the way, not a 2.6)
Markjay
  • London
« Reply #6 on: 15 January 2007, 00:59:33 »
Welcome, Dame Edna....
Alas, no more Omegas....
lachleaves
  • Anglesey
« Reply #7 on: 15 January 2007, 22:16:17 »
i did it - and it worked... well sort of!
with engine running, it was clear after 12, 129 then 132.
what's the 129 code??
I've checked the 'topbuzz' website - there's no code 129 there (under bosch motronic).
132 comes up as 'exhaust gas recirculation (EGR) valve - incorrect signal'.
does this sound right so far?
don't suppose anyone can tell me what it means?!
many thanks thus far,
lachleaves
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #8 on: 15 January 2007, 22:58:14 »
lachleaves
About 200 quid at a Vx dealer to change EGR & car may start to stall when slowing at  junctions before it fails.  Hope it's not faulty  :y
lachleaves
  • Anglesey
« Reply #9 on: 16 January 2007, 22:05:50 »
what's the expensive part of the job - the replacement valve or the labour??
and does anyone know what the code '129' is?  (it's not on the fault website)
what a predicament - i've only just got it!  ... and now i'm facing a £200 bill!  (don't suppose the diagnosis could be wrong?  a blip?)
...and anyway could the fault re-occur (nothing to do with having a recent exhaust + cats?)
many thanks anyway,
lachleaves
« Reply #10 on: 16 January 2007, 22:09:46 »
Soz, rebuilt my laptop and haven't got access to proper codes at moment...
lachleaves
  • Anglesey
« Reply #11 on: 16 January 2007, 22:33:58 »
you know you said 200 quid to get EGR replaced and it may start to stall...?
did you mean that despite paying VX to replace it - IT COULD STILL START TO STALL, STILL BE FAULTY??
lachleaves
  • Anglesey
« Reply #12 on: 16 January 2007, 22:43:00 »
just done a quick search - loads of members keep mentioning this EGR valve and a blowing exhaust.
mine's blowing a bit?  (could be a cause for the failure??)
where the hell is this EGR?  how do i get at it - as some members have mentioned removing it and cleaning it!
ta
lachleaves
Markjay
  • London
« Reply #13 on: 16 January 2007, 23:28:41 »
EGR Valve on V6:
lachleaves
  • Anglesey
« Reply #14 on: 16 January 2007, 23:31:24 »
lifesaver!
 :D
Pages: [1] 2 3  All   Go Up
