Author Topic: This Darm Oil Cooler and its lack of access  (Read 6494 times)
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: This Darm Oil Cooler and its lack of access
« Reply #15 on: 21 January 2007, 22:06:39 »
There is a good chance the water pump rubber seal will fail as well....
Its kind of on my plan B to do list  :-/
« Reply #16 on: 21 January 2007, 23:12:21 »
Markiec, good tip i have been told for afterwards is some bleach in the header tank to go around with the coolant.
Obviously don't run it for long, and flush it very well afterwards. But the bleach breaks the oil up and with a few flushes of pure water comes out a treat.
« Reply #17 on: 22 January 2007, 08:31:41 »
I wouldn't use bleach....alkaline products have a habit of attacking alloy, use a proper de-greaser.
If it was me, I would have the timing cover off so I could get the water pump out, then you can fill the valley section up with de-greaser mix and leave it for a while....pull the water pump and it drains the block again ready for flushing.....
Putting a hose pipe into the coolant pipe that runs arond 1/3/5 head with no pump fitted is a very effective way of flushing the block section....
Markie
« Reply #18 on: 22 January 2007, 15:06:07 »
Top tip Mark  :y
