lost power after 2000 revs
Started by v6 cdx, 22 January 2007, 18:42:37
Quotesorry to suond like a total dick but what do mean by blank it :-? :-/
Above the gasket, just put in a suitably shaped bit of coke can (or PM Issunaz for a blank)...
It wont help, you still have a blocked exhaust.....the hissing, is it from under the car?
If so its the exhaust gases forcing them selves through the pipe joins....
If it is EGR related it will be the corrugated metal pipe to the EGR valve...if the gasket fails there is very litte gas that can escape (the leak will be to small)
QuoteIt wont help, you still have a blocked exhaust.....the hissing, is it from under the car?
That diagnosis makes sense... :y
v6 cdx
is the egr valve leeking gases cusing me to lose power the exsorst seems to sound normal
No...the fact the engine is pumping exhaust gases against a blockage will cause you to loose power....
