Author Topic: DASH ILLUMINATION  (Read 1941 times)
Omegatoy
  • UK
DASH ILLUMINATION
« on: 26 January 2007, 20:25:55 »
Hi guys,
project Omega is all up and running sweetly but i have no dashboard illumination except for the mid display and the switch lights which work and dim with the rheostat after having a quick poke around and changing the bulbs in the dash i leaning towards the actual light switch being faulty,
any ideas? anyone had the problem before? anyone want to fix it for me?
Omegatoy
Re: DASH ILLUMINATION
« Reply #1 on: 26 January 2007, 20:29:31 »
strange one this, i have seen it. As he says MID works but none of the other dials, I gave it the old "techy" wack... no joy.
MID will DIM with Switch as he says.... its the first time i have seen that, normally its just been a loose connection.
Btw public thanks for sourcing the Rad  :y
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #2 on: 26 January 2007, 22:19:21 »
I'd send a PM to neonomega - it looks like there isn't much about Omega lights he doesn't know :y
Omegatoy
  • UK
« Reply #3 on: 26 January 2007, 22:35:33 »
lolololol
dont wont to neon it, just find the fault
its only a banger to get the mrs around while the insurance sort out the claim for the Mitsubishi Animal that was stolen,
BUT if its not right i get earache!!!! must get it fixed must get it fixed!!
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #4 on: 27 January 2007, 08:07:28 »
You've not by any chance had a faulty battery on the vehicle, or jump started it recently have you. Sometimes, when a battery goes faulty on a cell or two, the alternator is tricked and tries to compensate, the accumulator (Battery) can't harness this current as it would normally (BALLAST) therefore, any very fine fillaments in bulbs and sometimes sensitive radio's can go bump in the night..  Had this happen several times over the years..
Just a thought
DC
Omegatoy
  • UK
« Reply #5 on: 27 January 2007, 08:35:30 »
Just a thought
DC
Thanks Dave as a matter of fact the garage that couldnt get it running had jumped it and even put three batterys on it to turn it over faster!!! however having changed the bulbs this should have cured that particular scenario???
Omegatoy
« Reply #6 on: 28 January 2007, 10:37:18 »
Worth double checking the bulbs?  I think I have some here if they are blown (not new though, so may have short life).  Also, ensure dash fully seated...
Omegatoy
  • UK
« Reply #7 on: 28 January 2007, 17:33:35 »
sorted it thanks guys, I had just replaced the bulbs with some i had in the garage and when i took the dahs out again they were blown too!!!
its now working as should just got a damn oil leak to fix thenits all A1 :y
« Reply #8 on: 28 January 2007, 18:51:48 »
Glad to hear its sorted G, very tidy Estate that.  :y
