Author Topic: The idle valve thingy on the plenum  (Read 1944 times)
Essex_Andy
  • Have a guess?
« on: 28 January 2007, 19:53:34 »
How tight is this meant to be?
Mine seems a bit loose and feels loose....could easily slide it out of the plenum?
Just working out a list of what to do tomorrow when I remove the hopefully breaked HBV that may have caused the leak
« Last Edit: 28 January 2007, 19:53:56 by Essex_Andy »
If an artic overtakes you, you're driving too slow!!!!!!!!!!!
Taxi_Driver
Re: The idle valve thingy on the plenum
« Reply #1 on: 28 January 2007, 20:10:30 »
Sorry not too good on V6's but anything that is loose carnt be right!
« Reply #2 on: 28 January 2007, 20:59:52 »
Not usually a very tight fit, but if very loose, its going to be a problem...
Essex_Andy
  • Have a guess?
« Reply #3 on: 28 January 2007, 21:01:42 »
The part that fits onto the plenum is ribbed and has about 5 to 10mm of play...that acceptable?
« Last Edit: 28 January 2007, 21:02:18 by Essex_Andy »
« Reply #4 on: 28 January 2007, 21:06:53 »
As long as it always has an airtight seal, yes. If not always airtight seal, no.
