Author Topic: help !!!!2.5 v6 cooling fan problem (stays on!!)  (Read 1482 times)
googoo73
  • near luton
« on: 29 January 2007, 12:10:34 »
the cooling fan has come on and won't turn off until i unplug it .this morning i have changed the fan switch at the bottom of the rad and cleaned and re-filled the system .it even stayed on when the system was empty (engine not running)and the switch was un wired.it all started about two weeks ago when the fan started coming on after 2 miles .it uses no water and the temp. is around 85-90 c  but there is a cottage cheese like substance around the oil filler cap but as i only travel 2 miles too and from work in it every day i guess its breathing heavy.
any ideas how to fix the fan problem???
Re: help !!!!2.5 v6 cooling fan problem (stays on!
« Reply #1 on: 29 January 2007, 14:25:46 »
Two questions
1) Are you refering to the main cooling fan in the engine bay or one of the two fans on the aircon radiator.
2) Have you checked relay K26 in the engine bay ecu/relay box....it should be open circuit between pins A and B (fan should stop when this is pulled....)
Look here for details on K26 location
http://www.omegaowners.com/forum/YaBB.pl?num=1161602726
googoo73
  • near luton
« Reply #2 on: 29 January 2007, 18:35:52 »
it is the main cooling fan.
i have removed the blue relay and it wont come on .then i replaced it and all is well i will get a new one tomorrow .
thanks for the help :y
