Author Topic: Neutral without starting  (Read 2336 times)
AndersH
  • Poole
« on: 30 January 2007, 21:27:36 »
Need to do some work under the passenger side of the car but that side is near a wall. The car won't start so I can't move it - it also won't let me put it in neutral to push it! Is there any way to get the car in neutral without starting it?
Cheers,
Andy
Re: Neutral without starting
« Reply #1 on: 30 January 2007, 21:34:50 »
Auto? Ign on, foot on brake, move gearstick.
If battery disconnected, lift out gaiter and you will see the yellow park lock solenoid...
AndersH
  • Poole
« Reply #2 on: 30 January 2007, 21:37:15 »
As simple as that eh?! Now you mention it I do recall having to use the brake first to change the gear in happier car-working times!
Many thanks!
AndersH
  • Poole
« Reply #3 on: 30 January 2007, 21:47:54 »
Blimey! I don't know which was heavier, pushing the car or trying to turn the steering wheel! All done though now cheers.
« Reply #4 on: 30 January 2007, 21:48:57 »
1.7 tonnes is never easy to push ;)
« Reply #5 on: 30 January 2007, 22:26:01 »
Funny you should mention that, when my 2.2 died in the garage one night (flat battery) I could not move it, was in neutral and hand break off but could not move it 1cm.
When the Senator was in the same side, i was too close to open the bonnet. I pushed my leg in there and managed to rock it back about 3"  :-/ :-/
2.1 ton car thats an auto in Park is easier to push than a 1.7 ton car!!  ;D ;D
