Minor Electrical Probs!
Started by TDS3, 07 August 2006, 12:57:07
Kev
Quotetunnie you sure you have that the right way around my boot button will not work unless the key is NOT in the ignition.
Craig
Mine's is the same as your's Craig.
Well it was, until i carried out the Hilper Mod.  ;)
OmegaProject.co.uk .:.  Fuelled with passion...
[img name=signat_img_resize]http://i94.photobucket.com/albums/l92/xthreezero/omegaproject/oof-sig.jpg[/IMG]
TDS3
Thanks guys. I had a little play tonight and changed the ABS fuse and the Tracs & ABS light is now off for good and my speedo works,and the boot opens & the alarm button lights up too, brilliant lol....now my only problem is the stereo not working still, theres a fuse saying CD but the slot wont hold a fuse at all, it slips out, and the stereo is 2006 model, also in the glove box i have a manual for a sat nav type display but thats not working either although the time/date are ok.  Is there an easy way to remove the stereo without marking the fascia.  ::)
Craig_R
yep you need some keys to remove the stereo or some nicely bent metal coat hangers to fit in to the small holes on the front Oh also there are some little screws in the holes that need removing first before you can get the bent coat hangers in.
Depending where you are i have a set of the Keys to remove the stereo and i guess other members on here might have a set also
One thing i would check with the stereo is the fuse in the back of it I my memory serves me right there is one there.
Craig
Mod's
[To be Fitted]Reverse Sensors
Taxi_Driver
Craig
They changed it on the facelifts.....with the keys in and or engine running press the boot button for a short while and the boot will open.....actually thing about it....i seem to recall another taxi driver i know complaining he had to take the keys out if it for the button to work.....he drives a facelift 2.0.....so it may only be the case of the 2.2/2.6/3.2's
Cheers
It changed around 2001, as Vx must have realised taking keys out everytime was a PITA
Kev
QuoteIt changed around 2001, as Vx must have realised taking keys out everytime was a PITA
So did Hilper!!  ;D
Markjay
Quoteyep you need some keys to remove the stereo or some nicely bent metal coat hangers to fit in to the small holes on the front Oh also there are some little screws in the holes that need removing first before you can get the bent coat hangers in.
Craig
The key costs around £4 from Halfords or around £2+postage online. The spacing, in case you are making one yourself, is 85mm, and you need two keys.
Alas, no more Omegas....
Markjay
Quoteor 4 long thin nails ;)
...glued 85mm apart on a Magnum ice-cream wooden stick....  ;D
Kev
I've used 4 Allen keys in the past with the ball ends on.
Worked a charm.  [smiley=thumbsup.gif]
TDS3
Sorted all the problems, just needed fuse changing, thanks for all the advice.
Which fuse was it - the one on the back of the head unit?
Jay w
#27
Edited: should have read the entire thread....  :-[
nixoro
QuoteWhich fuse was it - the one on the back of the head unit?
Certainly sounds the case, had something similar when fitting my current radio.
Any chance of an update TDS3
Hillper
Quoteon a 2001 model the boot release button will not work unless the key is in the ignition and turned on to stage II
Check out the maintaince guides for 'Hilpers Boot Mod'
That will show you how to open the boot without the key in the ignition
I can't seem to find it!  :'(
Hey, LB, where have you put it?
Mods.  'Hillper boot release'.  Dimming mirror.  Cruise control. Rear parking sensors.  Becker/Rockford Fosgate/Infinity/Alpine audio.
