Author Topic: Sunroof Kit Removal.  (Read 2110 times)
ada-v
  • telford
« on: 31 January 2007, 13:52:28 »
how on earth do you get the cover and motor out of a meega??
i cant see any screws or owt to get the cover off and dont wanna snap anything.
cheers
ade
« Last Edit: 31 January 2007, 16:33:23 by Mark »
Re: sunroof kit remowal.
« Reply #1 on: 31 January 2007, 13:56:43 »
get a flat head screw driver, or the Mrs if she has good nails. (i bite mine)
There is a semi circle type shape in front of the dial (nearest the glass) pull that off, don't worry its clipped on. Just give it a firm pull.
Underneath you should see the motor and all its screws, often the mechanism just jams. Try some WD40 in there and some thin grease, rotate it manually and try and free it off.
« Reply #2 on: 31 January 2007, 15:35:47 »
Unless you want to get it out....in which case its courtesy light out whre you will see 2 screws and then pop the dial off to find a third......then it comes out....
ada-v
  • telford
« Reply #3 on: 31 January 2007, 16:30:58 »
cheers mark, thats what i needed.
just noticed, i have typed the subject title doing my Commander Checkov (original star trek. "captain, its an enemy wessel")impression. lol
Re: Sunroof Kit Removal.
« Reply #4 on: 31 January 2007, 16:33:43 »
Title modified.....
