Found the failure re coolant leak
Started by Essex_Andy, 29 January 2007, 15:01:09
Essex_Andy
#15
Here's the pic of the old cooler cover...spot anything unusual?!?!?!
Just waiting on the 30mm spanner to arrive from e-bay then can get the cam belt back on
If an artic overtakes you, you're driving too slow!!!!!!!!!!!
Its only supposed to have 2 holes....
Essex_Andy
all round that corner the underside is very corroded....but seeing the car is 8 1/2 years old not bad I guess?
Quoteall round that corner the underside is very corroded....but seeing the car is 8 1/2 years old not bad I guess?
My guess is the coolant has been neglected....
Essex_Andy
The unknown joys of buying a used a car but has got fully stamped book with receipts. I know the garage too
QuoteThe unknown joys of buying a used a car but has got fully stamped book with receipts. I know the garage too
and now you know their workmanship....
QuoteNever known a banjo bolt snap......so no need to replace....
Its not these that strip the cooler threads....its the bigger flat nut that secures the cooler to the plate...
I had a banjo bolt snap under v little pressure on my project Elite...
Thankfully managed to get one of those rounded bolt sockets tight over he snapped body of the bolt and remove it...
