Author Topic: Removal of Oil Filter Housing  (Read 7101 times)
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« on: 03 February 2007, 11:14:37 »
If i could find my original thread i would have added to it....
still cant remove oil cooler as we still cant remove the oil pipe nuts at oil filter end.
Reason being the lack of access and being unable to remove oil filter cannister.
We have tried EVERYTHING to get it off. Including socket on end with huge breaker bar and oil filter wrench on the houseing and turning them opposite ways,
Does anyone have an idea of how much the cannister is that houses the oil filter ( in y26se engine)
my only options are to give up on this ...
bend the cooler pipes to do it....
hack/drill/cut the bloody cannister and renew/replace it.
Its clearly been overtightened by some ars3hole garage with air tools........ >:(
« Last Edit: 04 February 2007, 10:21:43 by Markiec »
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: Darn oil cooler again
« Reply #1 on: 03 February 2007, 15:31:36 »
When i did mine Markie, ( and i know i'm probably gonna get shot for saying this ) I did it without removing the pipes, i know its not the right way, and i know you have to be careful, but it was actually fairly easy, hardest bit was getting the banjo bolt back in on the short pipe as you have to bend it slightly and it was hard to line it back up again, you could do with three hands at this point. What Mark , Matchless etc etc say is right, but its not as if you haven't tried ;)
Markie
« Reply #2 on: 03 February 2007, 15:57:54 »
i know...i've thought bout returning to that side of things but the way things are going i'd probably end up fractring a pipe...
Also - this darn cannister has got to come off....otherwise i cant do an oil filter change
Oh and ive started cutting it.... :-/ ;D
Markie
« Reply #3 on: 03 February 2007, 21:46:57 »
can anyone confirm if the main body of the canister is bolted or simply screwed to the engine block and if its clock or anticlockwise to remove... :y
« Reply #4 on: 03 February 2007, 21:59:19 »
bugger me that must be on tight!!
Hummm don't know what to suggest, the oil cooler can be removed if you bend the pipes but they will be bastard to put back.
But as you say you need to do an oil & filter change, plus if you started cutting it. Then its going to leak!!
I take it you have sprayed several litres of WD40 on it?
What about some of that Rust Magic stuff or whatever its called, MarkDTM will give you the propper name. That stuff does wonders...
An idea for getting filter off.... if the above does not work.
Get a drill and drill a hole though the filter.... then get a rod or pole, insert and turn. Sprinkle some words of black and blue that should shift the bugger!!
RolandL
  • Doncaster
    • M/facelift 2.5 V6 Elite
« Reply #5 on: 03 February 2007, 22:00:39 »
The cap on the end is screwed on, and should be 15nm, once the cap is off and the filter is out, there is a bolt that screws into the engine block and is tightened to 40nm IIRC.    When I changed my oil filter the cap would not come off, instead the whole housing came away from the block, anti-clockwise.  I was lucky and managed to get the whole unit back on and tightened up with a filter wrench.  A new filter housing is scarily expensive from VX I was quoted around....wait for it..... £170  :o  :o  :o.  I ordered an adapter for £5 ish, I plan to change it to a normal disposable cartridge type oil filter.
Hope that helps
Roland
The faster you go the bigger the grin.  Trade card user.
RolandL
  • Doncaster
« Reply #6 on: 03 February 2007, 22:14:35 »
The part number for the adaptor is 90412159.   To remove the filter housing I would suggest a filter wrench and a lot of steady pressure, anti-clockwise (lefty for loosey and righty for tighty) once off you need to get the cap off. One suggestion I have come across is to secure the canister tightly (in a vice would do) then use an impact socket on the cap nut, again anti-clockwise.
hope this helps
Markie
« Reply #7 on: 03 February 2007, 22:18:34 »
thanks Tunnie / Roland
Sh1t ...the price of that housing  :o :o :o oooops
15nm - that thing was (somehow) replaced with air tool tightness! probably a high street garage)
Ok ive already drilled a hole and put a strong screwdriver through....broke the screwdriver so i am going to do it tomorrow with an extension bar through it....me and my dad have spent a week on this and he as NEVER seen anything like this....this was also after wrecking two oil filter wrenches trying to counter load and snap the seal.
Roland....ive now got the cap off and is the bolt dead centre inside ? do you know the size from memory?
problem with this car/engine is its sitting different from the omega version and the filter is half way down at the front of the block.... and from top down you cant access it due to exhaust manifold hiding it.....front access prohibited by radiators ( about 6 inches of free space) and underneath access is through a minefield of sensors ( lambda etc etc)
And all this to get access to oil pipes to remove oil cooler - i realy relly want to folllow Mark DTMs advice and NOT bend them  :y
thanks again!!
Markie
« Reply #8 on: 03 February 2007, 22:19:44 »
Hope that helps
Roland
Roland this kit - will it be asimple as that to replace and is it a vauxhall part?
« Reply #9 on: 03 February 2007, 22:26:35 »
i can say from experience the oil cooler pipes are a bastard if bent!
There is no point bending them anyway if the oil filter is still buggered.....
No decent V6's at my local scrappy to get you a replacement housing  :(
RolandL
  • Doncaster
« Reply #10 on: 03 February 2007, 22:39:23 »
The adaptor is a standard VX part, it's a short bit of tube treaded at both ends. One end goes into the block, some thread-lock might be useful. Your new disposable filter screws onto the other end.
Have checked for a description of "bolt" and there are two possibilities one is described as a scew and the other as a torx M8 .As far as I know it is central
Markie
« Reply #11 on: 03 February 2007, 22:48:31 »
thanks Tunnie.....keep looking when you pass  :) :y beer tokens galore as a reward!!!!
« Last Edit: 03 February 2007, 22:49:15 by Markiec »
Markie
« Reply #12 on: 03 February 2007, 22:54:52 »
Thanks Roland L !
It s so hard to get to and see i am using an extendable mirror and torch to see inside it from under the car....
i presume therefor the bit sticking out the middle of the current filter must also come out of the sump....so the adaptor can go in at one end and stick out at the other so i can screw on the filter??
if every you find the part of that adaptor i`d be most grateful  :) :y
« Last Edit: 03 February 2007, 22:55:49 by Markiec »
« Reply #13 on: 04 February 2007, 09:27:55 »
Its either a big torx (rare) or a 27mm (from memory...)
omegaV6CD
  • Darlington
« Reply #14 on: 04 February 2007, 09:59:46 »
I had the same problem when i did mine, i ended up drilling many hole son the housing to take the cap off and then remove the rest of the filter housing. Then i got a brand new housing from the stealers which apparently is a newer design and in my opinion much better flowing. Get your powerdrill and start drilling.
Page created in 0.029 seconds with 20 queries.
