Author Topic: Steering Wheel Removal (Facelift)  (Read 1478 times)
edwardmickey
  • Milton Keynes
« on: 06 February 2007, 10:22:17 »
Gents,
Is there a link here that shows how to remove a steering wheel from a facelift model?  I need to remove the airbag and radio controls too.
Want to install an Irmsher steering wheel.
I recall needing a two legged puller on a Cavalier I owned many moons ago but couldn't get such a tool from anywhere.  In the end, a mechanic from Vauxhall in Abingdon used brute force but I cannot remember how he did it.
Thanks
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
Re: Steering Wheel Removal (Facelift)
« Reply #1 on: 06 February 2007, 20:46:38 »
firstly - turn off the ignition, disconnect the battery and wait a few minutes before starting - you don't want the airbag going off !!
from memory, there are two torx bolts in the sides of the wheel which hold the airbag in place - remove those and you can take the airbag out, disconnect the plug and store it face up.
Steering wheels unplug from a connector and can be removed easily, likewise the horn push buttons if needed.
There's a puller on fleabay here, cost is just over £15 ...
edwardmickey
  • Milton Keynes
« Reply #2 on: 06 February 2007, 21:11:58 »
Thanks, visited fleabay too!!!
