Author Topic: heater not working omega 2lt 96  (Read 2381 times)
Hughes_uk
« on: 07 February 2007, 14:34:10 »
hi all i have been trying to sort this heater out. turn knobes to hot luke worm then cold. so far i have changed thermostat water pump a bit Knackerd changd it. Refilled, bled same problem check all air pipes seem o k help please        john
Re: heater not working omega 2lt 96
« Reply #1 on: 07 February 2007, 15:13:53 »
Check all of the vaccum lines around the rear of the engine bay....
Hughes_uk
« Reply #2 on: 07 February 2007, 16:01:52 »
thanks for getting back so fast mark. I have checked pipes from servo to the under right hand side off bolkhead  ok. I have chang them around no drferent. Do you no if that unit has bean at fault in the parst?        john
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #3 on: 07 February 2007, 16:17:42 »
Can't the HBV cause luke warminess if its Knacked, If its got one of course?
« Last Edit: 07 February 2007, 16:19:15 by Timbuk »
Hughes_uk
« Reply #4 on: 07 February 2007, 17:42:26 »
hbv ? wear do i find this and what is it there for. the car has not got a/c. becouse the top hose on matrex is hot bottem cold tells me that the tap is not turning on to let water it  though matrex?        john
« Reply #5 on: 07 February 2007, 19:06:45 »
Hmm,  in that case i would think blocked matrix... :(
nixoro
  • Hitchin, Herts
« Reply #6 on: 07 February 2007, 19:10:11 »
Curious and just an idea but could it be a partially blocked heater matrix or even a leaking one, I didn't think non ac omega's had heater bypass valves.
Although if leaking the floor would be wet and it would smell.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #7 on: 07 February 2007, 19:10:31 »
Try running the garden hose through the heater pipes that go through the bulkhead, one and then the other probably find dirt will come out,  i haven't got an Omega yet but had the same problem with Our Rangey :y
Loo-knee
« Last Edit: 07 February 2007, 19:13:16 by Loo-knee »
Timbuk
  • Telford
« Reply #8 on: 07 February 2007, 19:16:52 »
Yup, just a stab in the dark from me, No A/C, no HBV
Hughes_uk
« Reply #9 on: 07 February 2007, 20:42:21 »
i have flushed matrex and engen with soder cristels and run hose though sistem. ime not that fermiler with thiscar. ime trying to help a old man out. souds like some off you are taking the ???        john
« Reply #10 on: 07 February 2007, 20:51:27 »
When you flushed through the heater matrix, did it run through easily and clearly - the the hose entering matrix being hot and one leaving cold to me means its not flowing through.... ?
