Author Topic: Removing gearbox selector switch  (Read 1575 times)
« on: 08 February 2007, 17:15:44 »
Any advice on where this is located, and how it is removed? Also size, how heavy/awkward is it, in postage terms. I need to get one off for STE.
Cheers
Re: Removing gearbox selector switch
« Reply #1 on: 08 February 2007, 17:23:13 »
Cheers
on side of box, passenger side iirc...
ste
  • West Yorkshire
« Reply #2 on: 08 February 2007, 19:19:45 »
Speak of the devil and he shall apear  ;D
It's on the passenger side of the box, held on by 2 screws/bolts.  If the gearbox is off the car it should be a doddle.  If not, you'll need to undo the 2 bolts with a socket (10mm, I think) slide it off the selector, bolt thingy that goes into the gearbox.  You might have to unhook the gear linkage first I think.  And disconect the electrical connector block at the top (this bit is a real bugger to do).
If it's on the car and you have to jack it up, please be careful. The though of people laying under a car rested on stands makes me cringe!!!   I always feel nervous when I'm under one myself.
If you have time and a small torx bit, the switch is held together with approx 6 screws.  Might be worth a look inside to see what condition it's in.  It's quite delecate inside though, so be gentle.
Hope this helps.
Ste.
