Author Topic: Flat Battery  (Read 5026 times)
cipher
  • Derby
Flat Battery
« on: 08 January 2007, 14:58:21 »
Hi,
Think the Battery is dead on the Omega.
Problem is, it is locked, and deadlocked, and I cant open the doors with either the Plip, or from the drivers door lock.
How Do I get in?  :-/
Breaking a 1996 'N' 2.5 V6 Omega
PM For Details
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: Flat Battery
« Reply #1 on: 08 January 2007, 15:58:14 »
Have you checked the battery in the remote ?  The car battery would have to be almost totally empty for it to not have enough power to activate the centralised locking system.
Can't see how it won't open with the key.  Mine does, even with the battery removed, but it's only the door that I'm unlocking that opens.
Try the passenger side lock, maybe the key/lock has been changed at some point and are no longer compatible.
Another option is to try the boot. Maybe the seats will fold forward and you can crawl in and reach the bonnet release that way. You may be able to fiddle the centre/arm rest panel as this is not held fast by a mechanical system. If you get access via the centre panel you should be able to reach the seat release buttons and fold 'em all down.
GOOD LUCK
No point trying to lift the manual doors buttons if she's deadlocked.
Thinking about it, I'm sure the owners manual advises not to use the deadlocks unless you feel it absolutely neccessary(or something like that) due to the hassle involved with your situation.
Bo Bo
  • Coventry
Re: Flat Battery
« Reply #2 on: 08 January 2007, 17:36:00 »
Don't think it'll have a passenger side lock?
The key will turn the lock, try some freeing oil in it first.
I've had this on mine & really had to turn the key hard, almost to the point that I thought it might snap, but it opened eventually.
Re: Flat Battery
« Reply #3 on: 08 January 2007, 18:10:17 »
It will unlock with key.  As its deadlocked, it will be incredibly stiff, but it should still unlock.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Flat Battery
« Reply #4 on: 08 January 2007, 18:22:27 »
I know what you mean, couldn't open mine when that happened, niether could the RAC man, ended up crawling underneath it to to put a connection on the alternator and an earth.
Managed to pop the remote then.
I like red cars
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
Re: Flat Battery
« Reply #5 on: 08 January 2007, 18:28:51 »
from memory, not only is the key stiff in the driver's door, but I think you have to turn the key to the right - as if to lock it - this is really stiff, turn back to horizontal then towards the left and it unlocks ... I seem to remember turning it to the left initially did nothing ...
JasonH
Re: Flat Battery
« Reply #6 on: 08 January 2007, 20:08:25 »
Not got saloon but is it possible to open the boot and get a trickle charger connected to the boot light. Should give you the juice to open the doors normally.
Admin
Re: Flat Battery
« Reply #7 on: 08 January 2007, 22:33:41 »
Well I had this exact same problem and came to the rather more straightforward conclusion...
Remove (or in my case break passenger side of) front grille (easy to replace) and simply reach in and pull the bonnet catch! :)
Lift bonnet!
The Administrator.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: Flat Battery
« Reply #8 on: 08 January 2007, 22:49:24 »
Lift bonnet!
Hooligan :D
I like red cars
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
Re: Flat Battery
« Reply #9 on: 08 January 2007, 22:49:47 »
Lift bonnet!
That's neanderthal  - why not just throw a brick through the window.  Tools required - 1 brick.  :-X
Markjay
  • London
Re: Flat Battery
« Reply #10 on: 09 January 2007, 01:56:47 »
Lift bonnet!
Nice trick... but (a) was it your car? (b) do you actually know the owner? (c) you nicked his oil filler cap, didn't you, because it was new and shiny yellow?  ;D
Alas, no more Omegas....
Hillper
  • Aylesbury
  • Werthers. Winter, too hard.  Summer, too soft.
Re: Flat Battery
« Reply #11 on: 09 January 2007, 08:01:28 »
Lift bonnet!
LB, I'm amazed at such a low tech (but effective, admittedly) solution.  ;D
Mods.  'Hillper boot release'.  Dimming mirror.  Cruise control. Rear parking sensors.  Becker/Rockford Fosgate/Infinity/Alpine audio.
Admin
Re: Flat Battery
« Reply #12 on: 09 January 2007, 08:10:43 »
Low tech it may be, but hey, it worked!  ;D
And yes AA, it is my car... ;)
The Administrator.
Re: Flat Battery
« Reply #13 on: 09 January 2007, 09:38:40 »
Lift bonnet!
How very disappointing  :-?
bigall
  • merseyside
Re: Flat Battery
« Reply #14 on: 09 January 2007, 09:52:44 »
Can you open the boot with your key?
 If so then press open the centre (ski slot) between the rear seats - sometimes the catch will detach or break ( cheap replacement)
Then hand around top to find the rear seat release then crawl inside and pull up lock thingy on top of door and open the door
I did this many times on my old 95 omega until the cause of the flat battery was found (12S socket leaking quite well)
I drive a moneypit Omega - at least its comfortable!!!!!  200k approaching rapidly!!!!!!!!! "") (must change oil soon)
